Generator? what is it and where?
Old Aug 3, 2004 | 01:11 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
Been reading my sucky Haynes manual, and he talks about a generator in the section of the alt,starter, dist. I dont exactly no if the generator is somthing in its self, or is this all these things he talks about. is the alt, battery, starting system, charging system and distribitor called the generator? if not, where is it located on my car? and one last thing, what makes up the charging system? thank u all.
Old Aug 3, 2004 | 01:52 PM
Xceleratemaro's Avatar
generator is an old aternator..the thirdgens dont have um..or the 2nd gens i dont even think the 1st gens had um.
hope this helps
Old Aug 3, 2004 | 02:03 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
vast majority of things used from the 60's on (probalby with some small exceptions) were all alternators. A generator has drawbacks and benefits, one of them is RPM, while at idle an alternator will produce the full 12 volts, a generator will not. My buddy's 1950 buick is a generator car, and uh, it'll be going the 12 v route soon, as that generator just doens't cut it.
Old Aug 3, 2004 | 02:07 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
does: voltage regulator + generator = altenator?
Old Aug 3, 2004 | 02:55 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
volatage regulator was also mentioned in that section. i think it does. not sure though.
Old Aug 3, 2004 | 03:32 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
generators produce DC, alternators produce AC which is converted into DC.
Old Aug 3, 2004 | 07:47 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
GM uses the term generator now. They figure that since the AC current is converted to DC, essentially it IS a generator and not an alternator.
Old Aug 4, 2004 | 12:40 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
The voltage regulator is the part of the alternator that prevents overcharging of the battery.
Old Aug 4, 2004 | 01:20 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
i know what it does, what i was asking is pretty much :: didn't they used to come seperate?
Old Aug 4, 2004 | 10:36 AM
I see. But I don't know the answer to that question.
Old Aug 4, 2004 | 11:45 PM
oil pan 4's Avatar
Car: 89 Firebird
Alternators use exciter field windings (an eletro magnet) on the rotor and the AC voltage is induced into the stator (the part around the rotor) .
Alternators use magnetic induction to retreve the AC form the moving parts, no brushes in moderen alternators.
A generator produces voltage that is inducted on the rotor from regular magnets on the stator. That voltage that is produced is AC that is mechancly changed to DC with the communator and burshes. Old generators have brushes that are there week point.
All generators and alternators produce AC but how is is made is the difference between them.
I work on alternators big and small all the time. I know them in and out.
Old Aug 5, 2004 | 08:27 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
great knowledge sir. your appreciated.
Old Aug 15, 2004 | 01:07 PM
chevytruck68's Avatar
Car: 86 camaro
Engine: 2.8
Transmission: 5 speed
yes the regulator and alternator used to come seperate they were on my 68 chevy truck
Old Aug 16, 2004 | 11:43 AM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
thanks for the update sir
F-body-fan
May 4, 2026 09:42 AM
Linson
Oct 1, 2015 09:50 PM
James Sutton
Sep 23, 2015 02:18 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
Hill1513
Sep 19, 2015 04:15 PM
