Uggg, I'm sick of these problems
Old Aug 24, 2004 | 01:00 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I have a power problem somewhere... Not sure where thoe. I can jump it, and it runs fine, but the second I turn it off, its dead. What should I do?
Old Aug 24, 2004 | 01:03 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
ok does it run fine as long as its hooked to the other car, then die when the cables are taken off?
or does it run fine after being jumped then when you turn it off, you can't get it started again?
if its the first one its your alternator
if its the second one its your battery
Old Aug 24, 2004 | 01:18 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Battery probably has a bad cell. You could charge it for days and it'll never hold a charge.
Old Aug 24, 2004 | 01:21 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i'm thinking dead battery but if its dying right away its the alternator
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
