Stutering then shutting off...
Old Sep 6, 2004 | 09:04 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Hello Yall,
As I was driving home tonight from my girlfriends house I noticed a stumble coming from my car when ever I hit the brakes. When i would come to a stop it would drop from about 1200RPM down to 500RPM and then bounce to 700RPM and idle rough. It did this a couple of times and then when i came to a light getting to my house the car just shut off. The IAC is new so are the plugs, wire, Coil, Cap, Rotor. The fuel filter is also new and I cleaned out the air filter recently. Can it be my fuel pump taking a dump or do I need to get another IAC? Please help i hate when my car acts stupid...
Old Sep 6, 2004 | 11:00 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
could be a fuel pump issue, but u won't know unless u can check the fuel pressure, get urself a guage and try it out.....don't decide to replace it for grins, as you might find urself hunting in the dark.
Old Sep 7, 2004 | 08:45 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Did you clean out the IAC passages when you replaced it?
If the stumble gets worse when you apply the brakes, sounds to me like a vac leak...
gta892000
Aug 11, 2019 11:16 AM
Gunner242
Dec 25, 2015 04:49 PM
ironbmt
Sep 27, 2015 06:00 AM
wisemanz28
Sep 20, 2015 01:26 PM
