timing chain and engine oil
Old Oct 3, 2004 | 06:31 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
can i use a cloyes double roller timing chain with my stock valvetrain? also im changing my oil tommorow i got a k&n oil filter and royal purple oil do you recommaned useing lucus additive with royal purple?
Old Oct 3, 2004 | 08:53 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep; I've got the same timing chain, and my valvetrain is stock. Follow the directions on the box tho- you can't use the factory tensioner (rubber-covered metal "V" between the cam gear and crank gear) with that chain. I kept my tensioner; it's somewhere in the basement.
As to additives; I don't like using 'em- I used to be a diehard Slick-50 user- I put that $20 bottle in with every oil change! Then I found out how teflon can clog oil filters and build up in engine oil passageways, so I stopped using it, and havent' used it since. That was, oh, I guess in 1995 or so? Now the same motor has 272,000 miles on it, so I wouldn't really recommend oil additives. Regular oil changes is the way to go.
Old Oct 3, 2004 | 10:32 PM
Ovrclck350's Avatar
Speaking of, I have a brand new one in the GM plastic wrap in the closet if anyone wants it.
$5 + Shipping.
Old Oct 3, 2004 | 11:02 PM
oil pan 4's Avatar
Car: 89 Firebird
sounds good, don't use the addtive.
Save it for the lawn mower.
Old Oct 4, 2004 | 03:41 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
timing chain
thanks tom
Vintageracer
Jan 10, 2020 05:33 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
