mods hp/tq guess
Old Oct 9, 2004 | 09:01 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
mods hp/tq guess
i got a list of all my mods. how much tq, hp to you think i gained. also how much seconds off stock 0-60 time do you think i have with these mods?
-custom cai
-dynomax super turbo catback
-dynomax high flow cat
-pacesetter headers/y-pipe
-asp crank pulley
-hypertech chip
-optima battery
-accel super coil
-accel cap/rotor
-accel ignition wires
-trans go shift kit
-b&m kickdown kit
Old Oct 9, 2004 | 09:09 PM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
i would guess between 150 and 160. the optima will slow the car down (probably nothing noticable) it is heavier than most batteries. the chip could be a problem too, altough i am just guessing. with all the work you have done a custom chip would help you.
Old Oct 9, 2004 | 09:20 PM
dcm01003's Avatar
Car: Black 89 Camaro RS w/t-tops
Engine: 2.8L (173ci) v6
all those mods would only add 10hp??
Old Oct 9, 2004 | 09:35 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
most of those mods dont make power
like the trans shift kit doesnt make any power it just makes quicker shifts
well yes and no. i am assuming there is a good bit of mileage on the engine. the timing chain probably has slack in it, ring seal is not optimal, the valve job is worn, carbon covering parts, and the fuel pump could be starting to lose pressure. and like i said it would probably benifit from a custom chip. you don't just bolt on x number of horsepower everything works in conjuntion with one another.
Old Oct 10, 2004 | 12:41 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Exhaust/headders are really the only thing freeing up any power (POSSIBLY the pulley). Even if you only gained 10hp, it's more than a 16% gain, which is pretty good. Add a cam and work the heads, you'll REALLY benefit from it.
Old Oct 10, 2004 | 10:52 PM
dcm01003's Avatar
it seems to me that almost all those mods would work together to add power. with the exception of the tranny mods they all do something to increase air/exhaust flow and improve the use of fuel in the engine. But i guess it could still be the case that the engine is high mileage...
Old Oct 10, 2004 | 11:36 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
you won't see any MAJOR gains until you do a cam swap and some good valve springs and a good port and polish job throughout everything. then, you'll need a bigger throttle body to help out your airflow.
Old Oct 11, 2004 | 12:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: mods hp/tq guess
Originally posted by 91greenbird
-b&m kickdown kit
Sweet!! I'm so glad to see that someone else here installed one! That's a fun mod, isn't it?
Why guess, though? Walk thru the phonebook and find a place that has a chassis dyno! I think it's usually about $100 for a few runs, and if ya do it, show us the power graphs!!
Old Oct 11, 2004 | 03:53 PM
Car: 91 Camaro
what exactly does the 'kickdown kit' do?
Old Oct 14, 2004 | 07:24 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
kickdown kit
i dont have this yet but i know it will make your car shift into overdrive and stay in it instead of downshifting to third
Linson
Oct 24, 2025 02:00 PM
Ed1LE
Sep 30, 2018 09:14 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
