Might have fixed my oil leak
Old Oct 14, 2004 | 02:09 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Wow! its been forever since I posted a topic...
Anyway, over the past two years I have been sealing up my old '83 2.8 Camaro. I was forever plagued by a leak that would occur during a right hand turn. Changed valve cover gaskets, rear main oil filter housing, pressure switch yadda, yadda, yadda... still was happening.
Well I think its fixed now.
Apparently the PCV baffles in the stock valve covers are sub par. What was happening on a right hand turn was oil was getting into the PCV valve and re-deposited in the air cleaner and leaking out the drivers side of the motor.
The fix? pretty simple and cheap really. I purchased a coolant catch can from Summit racing for $14.50. Removed the top connector and widened the hole enough to accept the PCV valve and grommet. Then I drilled a hole in the side of the can and threaded a 3/8 inch hose fitting in it.
I removed my PCV valve and grommet and replaced it with the grommet found on the passenger side of the later 2.8's (85-up) and ran a hose from the valve cover to the hose fitting and another from the PCV valve to the motor.
So far no more leaks when turning!
Old Oct 14, 2004 | 07:45 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Sounds Like a prime example of do it yourself inginuity.
Rock on man!!
~Max
Old Oct 15, 2004 | 12:18 PM
MDv6man's Avatar
Car: 1983, 1986
Rock on man!!
~Max
Hehe... actually I got the idea from a Mopar Magazine of all places. Just goes to show knowledge can be found from many different places.
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
MY87LT
Aug 17, 2015 08:43 AM
bamaboy0323
Aug 15, 2015 07:20 AM
drathaar907
Aug 6, 2015 04:20 PM
