Help Me Find My Thingy
Old Oct 17, 2004 | 07:19 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
I have a 2.8L V6 carbbed and i cant finy my oxygen sensor! its not any where to be found.....pics would be totally awsome
car is an 83 camaro berli
Old Oct 17, 2004 | 07:27 PM
Russ-So Cal's Avatar
I once had a 84 2.8, the o2 sensor was in the exhaust manifold on the passenger side if I remember correctly.
Old Oct 17, 2004 | 07:28 PM
It is in the passenger side exhaust manifold if I remember correctly.
Old Oct 17, 2004 | 07:29 PM
Car: 1987 Z28
checked it dude......nothing....its almost like there is none... This is my last chance at getting some fuel milage cause my v6 is taking 1/4 of a tank to get me into the city and back and i live only 30 kms outside of the city
Old Oct 17, 2004 | 08:11 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Get under the car and follow from the manifolds to the muffler, inbetween there SOMEWHERE is the O2 sensor
Old Oct 18, 2004 | 12:06 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
well, here's a thought. was the car originally sold in canada? if so, you might not have an O2. do you have wiring going to the carb?
Old Oct 18, 2004 | 12:24 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Good call, '85! I think we had one of those pop up here once.
Old Oct 18, 2004 | 06:19 PM
Car: 1987 Z28
man, i really need a picture or something....what wiring for it from the carb!?!? what color is this "phantom" wire thanx for the replies though
Old Oct 18, 2004 | 06:27 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
if you can't look at the carb an see a wiring harness to it, then you don't have a computer controlled carb, which means that you don't have an O2 sensor.
From what i understand, and TomP seems to have confirmed...1985 was the first year for computer controlled 2.8L V6, which means taht you don't have an O2. If you did, it's not gard to find, just after the y-pipe joins the 2 banks together. there is a single wire connected to it and it is just before the CAT.
Old Oct 18, 2004 | 06:46 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Lol I looked for ages for mine on my LG4. Then I realized it didnt have one.
Maybe someone removed it?
Old Oct 24, 2004 | 12:25 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Computer controlled 2.8's were used first back in like 1980 or so, BUT I remember a few posts way back where Canadian F-bodies did not use feedback carbs. If the carb doesn't have a mixture solenoid on it, then it isn't a feedback carb and shouldn't have an o2 sensor.
Old Oct 24, 2004 | 12:38 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
just as an update on information. I saw a federally certified 1983 carb'd 2.8 yesterday and the O2 is in the passenger side manifold if equipped. You can look right down and see it. Chances are that you don't have one since it would be painfully obvious if it were there.
Old Oct 26, 2004 | 03:43 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
they still call it "mileage" in nations that use the metric system?
shouldent it be kilometerage?
ChristinaMarie
Sep 11, 2015 06:28 PM
NiG
Sep 7, 2015 11:25 PM
Street Lethal
Sep 7, 2015 01:09 PM
