idle surge on startup
Old Oct 20, 2004 | 03:06 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
alright, replaced the cap and rotor and i'm still getting a bit of hard start, if i turn the key the car will start but it feels like its gonna stall for a second, then surge up to 2500 rpm, and hold there for about 3-4 seconds. i checked the plugs, and they all burning right with no oil on them. everything under the rotor on my distributor are rusty as hell, and i'm getting smoking from the back of my motor(i think its the distributor o ring)
anyone have any ideas what the problem or problems could be? i replaced the pcv valve about a month ago.
also when i leave the car sitting for a few days it'll start up great with the first crank but not afterwords, it also starts up warm quite well
Old Oct 20, 2004 | 08:36 PM
firebirrrrd's Avatar
Re: idle surge on startup
Well the rusty stuff cant help any. Rebuilding the dist cant hurt any. It isnt too hard to do either:lala:
Old Oct 21, 2004 | 02:48 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
lol, yes the distributor rebuild is pretty high on my list right now
anyone else have any ideas?
Old Oct 21, 2004 | 10:42 AM
mvftw's Avatar
How about your IAC?
Old Oct 21, 2004 | 02:55 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
hmm, what the proper way to check the iac?
i'm gonna get an egr valve and see if that works too
Old Oct 21, 2004 | 08:07 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i know someone here has an idea what to do to fix this
Old Oct 22, 2004 | 08:26 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Can't really check the IAC. Just take it out and clean all of the gunk off it with some TB cleaner. Also spray the cleaner into the TB.
If that doesn't help, they go for about 25 bucks
tyeo098
Nov 30, 2015 06:27 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
banksGTA
Sep 13, 2015 11:56 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
