What the hell is this???
Old Oct 27, 2004 | 09:02 PM
Jaswir's Avatar
Car: 88 Camaro RS
Engine: 2.8L v6
Transmission: TH 700R
Wondering if anyone knew what this is on the air intake on my 88 camaro v6 2.8L... i tried going to the auto part store and no one could tell me what kind of sensor it was or anything click on the link and let me know if u know
http://www.cardomain.com/memberpage/526779/2
Old Oct 27, 2004 | 10:58 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Believe it or not, that is the Manifold Air Temperature (MAT) Sensor.
Old Oct 28, 2004 | 12:06 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Just as Trickster said. Did you take the parts guy out and show him? They should be able to figure it out if they see it. There's also a really easy resistance test to see if it's good or not (although I don't recall the test right off the top of my head).
Old Oct 28, 2004 | 05:30 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I'll take care of all your problems with that if you wanna trade intakes.
Old Oct 28, 2004 | 10:08 AM
Jaswir's Avatar
Car: 88 Camaro RS
Engine: 2.8L v6
yes i took the part out, i went to autozone and advanced.. advanced went threw them all because they had pictures of the part on the computer he couldnt find it or tell me what it was...
Old Oct 28, 2004 | 02:14 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I think it is a dealer only item i remeber i had looked at AZ pepboys and napa and none of them had the part. You can search under a 92 olds cutlass supreme v6 3.1 sae sensor i dont know if it may show for that year but i know both sensors are the same.
Old Oct 29, 2004 | 12:26 AM
I found the MAT at a local parts store. According to GMPartsDirect, the OE number is 25036751.
Old Oct 30, 2004 | 06:49 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
I just bought one at Autozone. They call it an Air Charge Temperature Sensor.
If you want to check it first. The resistance at 70 degrees F should be about 3400 ohms, 100 deg = 1800 ohms, 160 deg = 450. Mine was reading 380 ohms at 70!
Old Oct 31, 2004 | 12:38 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Were you getting a code when it was reading that high? (curious because I've never seen one go bad on these cars)
Old Oct 31, 2004 | 08:00 AM
bru333's Avatar
Car: 1987 Camaro SC
I didn't check for codes. The SES light wasn't on either. I was chasing a cold start up problem and was checking all the sensors when I found it. I just swapped in a reman 2.8 long block and reused all the old sensors. I could have saved myself some headaches if I had replaced them all or tested them before reusing them.
Old Oct 31, 2004 | 07:21 PM
My MAT sensor went. It threw a code and failed the resistance test.
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
92camaro350cci
Oct 14, 2015 09:29 AM
aaron7
Sep 30, 2015 09:15 AM
dimented24x7
Sep 6, 2015 03:51 PM
