Does our cars use vaccum to control the defrost and heater, etc? If they do then where is that black ball looking thing if we have one. Sorry i do not know the name of it. Thanks
-Buck
-Buck
The heater valve is controlled by vacuum.
The vacuum resevoir (black ball) is inside the front bumper cover under the left headlights. You can see it from under the car.
Mine is crushed, where can i get one at?
-Buck
-Buck
Also is the hose the only thing connected to it or is there an electrical connetion also?
-Buck
-Buck
Just one vacuum hose to the ball. No other connections.
www.buy-oem-parts.com look under collision parts, cruise control system, vacuum tank. it is $15 plus shipping. They usually use UPS ground.
Or try a junkyard. Not like its an item they would want much for. Doubt many are removed either!
If you can find one in a junkyard! A pick your own part place is your best bet. Saves having to explain what you are looking for, and the odd looks "You're looking for a what?".
Here's another thread on the black ball.
https://www.thirdgen.org/techbb2/sho...hreadid=248122
Originally posted by Doward
Someone here once claimed it was....
THE ORB... OF POWER!!!
originally posted by Nixon1
That was me, d*mnit, that was me!
