Temp Gauge
Old Dec 4, 2004 | 01:23 PM
90camaropb's Avatar
Car: 90 Camaro
Engine: v6 3.1L
Transmission: 700r
Temp Gauge
I went to turn on the car this morning and the temp gauge isnt working? is this an easy fix ?
Old Dec 5, 2004 | 05:28 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
might be, it depends on whats wrong. Have you tried checking the sensor in the back of the passenger side head?, Check to see if it is disconnected. Do you have a Digital Voltmeter??? If you do, let me know and I will draw you up a diagram so that you can check the sensor and wiring for proper operation.
Old Dec 16, 2004 | 04:27 PM
Buck89RS's Avatar
Car: 1989 RS
Engine: 2.8L MPFI Bored 30 over (Rebuilt DEC 2004)
Transmission: 5 - SPD With 3.42 open rear end
On my engine the sensor is on the driver side head in the front behind the power steering pump...or is it on the intake..but it may be differnet on the 3.1 but i think that the sensor that 2.8 boy was talking about is the fan switch. And if i remember right it turns the fan on at like 220 degrees or something. The reason i say that is because if you ground the wire out that is going to that switch the fan will come on. Anyway my 0.02
-Buck
Old Dec 17, 2004 | 07:34 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
If you ground the wire attached to the temp sensor, with the key on and engine not running, the gauge should peg out high. This would tell you the temp gauge and the wire are ok, and sensor is bad.
When you start the engine the gauge should peg high also, while the starter is running. If it doesn't, temp gauge bad.
Temp gauge sensor is on driver side head at front, single wire. The fan switch is on the pass. side head rear, single wire. Fuel injection cold start temp sensor in the intake manifold below throttle body, next to the cold start timer, two wires.
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
corey8084
Sep 17, 2015 02:56 PM
