shhhhhhhhhhhhhhh sound when heater on
Old Dec 7, 2004 | 11:52 PM
PILU's Avatar
Car: Firebird 89' and Formula 87
Engine: 2.8 l and 350 v8
Transmission: 2.8 Manual 5 speed and 5.7 manual 5 speed
when I put the ac stick on hot ( or the red) theres loud shhhhhhhhhhhhh sound, And I dont Know where is this coming from, Is it a vacumm leak?, also my car backfires alot after I run the car for abut 10 minutes it stops backfiring, the backfiring happens all the time no matter where the ac stick is hot or cold.
Can somebody help me Im really confused.
Old Dec 8, 2004 | 12:07 AM
nsimmons's Avatar
you check the vacuum or the timing? You can buy little kits for 20 dollars with a vacuum gauge, timing light and tach.
See if the vacuum is stable and check your timing.
The ac should make a sound when you move the control. How loud is to loud? Got me.
Old Dec 8, 2004 | 12:15 AM
PILU's Avatar
yeah its very loud, It did'nt sound like that before I have own the car like for 4 years and that soud started like 3 weaks ago
Old Dec 8, 2004 | 12:18 AM
PILU's Avatar
also when I acelerate the shhhhhhhhhh stops, if I keep the foot out of the accelerator the sssssssshhhhhhh continues
Old Dec 8, 2004 | 12:26 AM
nsimmons's Avatar
Sounds like vacuum then. When you floor it vacuum drops to zero.
Get a vaccum gauge and check it out. Should hold a steady 17-18" (at least).
Of you could temporarily disconnect the vacuum soure to the heater box under the hood, (plug the line) and see if it goes away.
Old Dec 8, 2004 | 05:35 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I get a hissing sound, its from the back side of the ac/heater control. The rubber hoses are fitting perfect, and I have to give a slight tug on them to shut them up. But this is easy when you dont have a radio in the dash
Lbibb
May 5, 2016 12:00 AM
jrdturbo
Mar 31, 2016 02:58 PM
tmellott89
Oct 14, 2015 02:06 PM
wanext
Oct 6, 2015 12:18 AM
gord327
Sep 29, 2015 10:18 PM
