Headers?
Old Dec 9, 2004 | 10:28 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Headers?
I have read millions of posts on this site. I am 17 and own a 1988 Firebird as you all know. I was looking to invest some money into headers. Is it actually worth it? How much money is it all together, headers, y pipe etc? Can you feel the difference? Thanks guys
Old Dec 9, 2004 | 10:31 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
definately worth it! from what i hear, the pacesetter headers are on hold right now. i forget the price on them, but, they do include the y-pipe and all. if you go and do more to your engine, you will feel even more of a difference!
Old Dec 10, 2004 | 04:10 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
pacesetter headers are like $220 shipped.
Old Dec 10, 2004 | 07:52 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
$227, I believe, shipped.
Old Dec 10, 2004 | 08:00 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Thanks guys, so they are highly recomaned and is there alot of custom fab. to do? Thanks
Old Dec 10, 2004 | 09:07 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
hold out for the pacesetters. i put them on mine, lil bit more sound (w/ dynomax and catco cat) and you can feel a difference. maybe not huge but a difference. mine were at the door for $217. check the stickys to find out the email addy for the guy at pacesetter and see how long theyre gonna be on hold. they had to refab the driver side header to make room for the longer oil filter. i just decided to run the shorter one and not worry about it, that was before they stopped production of them.
Old Dec 11, 2004 | 12:33 AM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I've got the older style, never used, been out of the box once. I decided an S10 or Blazer would work out better for me to carry my stuff to school. I'm looking for somewhere to go with them since my return period has ended email me if your interested, we can talk about price and whatever ( Dgrocho@hotmail.com)
If anybody is looking for a camaro....
There is no fabrication necessary, just bolt them up and go. I think Dale got them up in under an hour or something
Old Dec 11, 2004 | 12:10 PM
Engine: 2.8 Lt
Transmission: 5 Spd
I don't have the money right now, but was interested in some headewrs, how do you fab up the y pipe or does that come with them? Thanks guys
Old Dec 11, 2004 | 12:45 PM
drdave88's Avatar
Engine: 6.0L
it comes with, as well as all the bolts and clamps you need. when i installed mine, i had to remove the bracket on the back side of the alternator though. it shouldnt hurt anything though.
Old Dec 11, 2004 | 04:55 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Then you put the braket back on right? Is there a website for Pacesetters? How much horse you think you can gain from this? Thanks guys
Old Dec 11, 2004 | 05:11 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I was the first to get the headers. I informed them of the oil-filter hitting the headers.
My car didnt have a bracket on the back side of the ac, so I'm "not missing it".
As for torque, I noticed more. But I know my tranny is slipping bad.
Somewhere I here, I posted a link of everything you had to do to get them on. Two people put them on in one weeknight after work.
Old Dec 11, 2004 | 06:05 PM
Doward's Avatar
Damien, PM me... what price are you wanting?
Old Dec 11, 2004 | 08:32 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Originally posted by Dale
I was the first to get the headers. I informed them of the oil-filter hitting the headers. My car didnt have a bracket on the back side of the ac, so I'm "not missing it".
Is the oil fitting problem fixed now? What bracket are you talking about, the alternator one? My car has AC and the stupid AIR pump so all that has to be removed. The y pipe that you get, does that bolt right up to your stock hanger and the stock cat? Thanks again
Old Dec 11, 2004 | 08:51 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If you asked nice and paid for all shipping I bet they would exchange the older "bad" sytem for a new one. As like Dale said they are to close to the oil filter and are not worth installing on anything. I bet they would do it.
Old Dec 12, 2004 | 09:44 AM
drdave88's Avatar
Engine: 6.0L
im talking about the triangle shaped bracket that bolts up to the alternator and the pass side exhaust manifold. i dont have a pic of it and the car isnt here right now, otherwise id get you a pic. but it sounds like not every car has this bracket, so you may be all set
Old Dec 12, 2004 | 03:00 PM
Dale's Avatar
Engine: 350 S-TPI
The reason the headers are on backorder or whatever is because of the oil-filter situation. They were very concerned about it, more then happy to correct the situation. I sent them plenty of pictures.
Yes, you will have to remove the smog pump.
I know my car has had the heads redone, this bracket may have come up missing at that time. But either way it goes, 2-3 years this car has been missing that bracket and no problems.
AC wont need to be removed, not one part, even temp for install. The alternator will need to be temp removed for install.
Y-pipe was the easiest part to put on. My car is for *cough* "race only". The y-pipe stops in a place where the stock cat can be removed from old section, and put on new section. Hope that makes sense? I suggest while getting the cat welded on, have them weld the slip-joint on the y-pipe also.
Old Dec 12, 2004 | 03:41 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Thanks man, so I have to take off my AIR pump and leave it off? Don't I need that for inspection? Yeah I knwo what bracket you are talking about now. And you are saying the Y pipe stopss where the stock one did? Thanks guys
Old Dec 12, 2004 | 04:56 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Don't have inspectin hear so don't know what to tell you oon that, but alot of the 2.8s came w/o smog pumps from the factory...mine was smogless. Egr only. I even removed that and as long as my timing is at 10, even with the big cam, I pass emissions.
I got the first set of PF & E headers. They cost more then the pacesetters, not sure how much (were a b-day gift), but they are stainless with a y-pipe. They have no fittment issues. Clear the oil filter with a bigger truck filter fine! Very happy with them!
PF&E headers 586-949-3400
Old Dec 12, 2004 | 06:11 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Thanks guys, not sure what i have to do to take the air pump off or weather it even needs to come off. Let me know, and how hard is it to take it off? Thanks guys
Old Dec 12, 2004 | 06:43 PM
Doward's Avatar
Ah, it's not hard at all to remove. You'll have to remove it anyway, for the turbo kit - but now I'm thinking I could really use a picture of the passanger side header, from a couple angles, installed - just to be sure I have room for the downpipe!!
Old Dec 12, 2004 | 08:29 PM
Dale's Avatar
Engine: 350 S-TPI
dow, you need pics? PM me what type of angles you need. I got stuido lights I'll throw on it while snapping pics.
y-pipe stops not far from behind the tire. but where you can clamp on a cat, and bolt it up to the rear section. I guess I could take pics of that too? Mine has a cut-out rather then a cat.
Old Dec 12, 2004 | 08:46 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Can I see the pics too? That would be great So the air pump has to go right? Thanks again guys, very helpful
Old Dec 12, 2004 | 10:21 PM
Doward's Avatar
Straight down from up top, and from the front going back almost level with the header tubes from the exhaust ports should work.
Old Dec 12, 2004 | 10:27 PM
Doward's Avatar
Old Dec 13, 2004 | 07:07 AM
Dale's Avatar
Engine: 350 S-TPI
Will see what I can do
350man, On the same link/page as I typed up for the install, I have pictures loaded of the install, and few other things.
Old Dec 13, 2004 | 09:24 AM
Engine: 2.8 Lt
Transmission: 5 Spd
What link were you talking about? I looked at your website but its not on there. Thanks for the help Dale
Old Dec 13, 2004 | 09:42 AM
Dale's Avatar
Engine: 350 S-TPI
:delete link:
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
