Where to find a crank pulley? and ?? about AC delete
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Where do you guys suppose I'd be able to find a crank pulley, balancer pulley, whatever you want to call it, the one that goes on the crankshaft. None of the local parts stores carry it, would the local junkyard be my only hope?
I am sick of the low voltage situations from the underdrive pulley.
And if you do an AC delete, do you take the compressor itself off or just disconnect everything and take out all the old stuff?
Also, do you have any problems with defroster or anything after doing that
Car: 1998 Camaro Z28
Engine: 6.0L
just take the A/C compressor off and get a belt for a non-A/C car. everything else is the same. do you also have the alt underdrive pulley? if so,that may be your problem. i have a system and a crank underdrive pulley and never had a problem. check your charging system too, may be a problem there.
nah, just the crank. I've got a sub and amp as well, nothing major. The guage shows that it will get about down to 8v at idle. This causes all my lights to dim, and I'm afraid it may have a part in the death of my starter as well as a possible pcm or ignition problem that I am having as well, so before I do anything, I just want to get back to stock. Mostly I am trying to get this car to be very reliable and pass emissions.
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Yeah, I had it checked out, its putting out 14.4v at idle, and the battery is fine too, so maybe my guage is just really sensitive.
Pretty easy check...go get a spare voltage gauge from a parts store... temp rig it up with spare wires. Just twist the wires together. May give you a better idea what is goping on in the low volt situation. help eliminate the gauge or pinpoint it as the prob. Then you can return the gauge if nothing it wrong with yours. I have an aftermarket auto meter gauge, so I can't comment on how accurate the factory ones really are!
ambainb
Apr 25, 2016 09:21 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
Street Lethal
Aug 12, 2015 11:33 AM
