E2SE carb > tps adjust?
Old Dec 11, 2004 | 09:03 PM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
Where do you adjust the tps on a v6 2.8 Rcch E2SE carb? (The 173 engine code)
Thanks guy
Old Dec 11, 2004 | 09:11 PM
CamaroManBlack's Avatar
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
You don't adjust it....it just drops into its little spot at the side of the float bowl case....the arm/lever that works the accelerator pump also works the tps, which sits in its space on top of a spring that keeps it up in place against the underside of the air horn (top of the carb.). Neither the TPS nor the Mixture Control Solenoid have an adjustment on them, mechanically speaking. If you can, get a repair manual and look at an exploded view of the carburetor; you'll see what I'm talking about.
If yours is malfunctioning, then you'll have to replace it. Not hard, just take the top of the carb off, pull the old tps out, drop the new one in, and put the top of the carb back on with a new gasket.
Old Dec 11, 2004 | 09:31 PM
azcamaro's Avatar
thanks
86CamaroDan
Sep 29, 2015 10:08 PM
Strick1
Sep 4, 2015 07:11 AM
andy74
Sep 3, 2015 08:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
86IROC112
Aug 21, 2015 07:20 PM
