What can be removed on 2.8L engines that can help free up space
Old Dec 14, 2004 | 07:35 PM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
My engine bay is a crowded mess. Lotsa wires and everything all around. Anyone have tips on getting the engine bay a lil more... "clean". Whether it be organization and such, possibly removal of components I can do without.
Just looking for tips really... You guys have had the v6s longer than I have ... probably car experience overall heh.
I just got done taking off the valve covers last week so I could replace the gaskets (picked up some fel pro cork gaskets) and went ahead and painted them while i was at it. It was hard because of so much in the way.
So tips... tricks... anything would be appreciated
EDIT: Just to add, I have taken off the smog pump and disassembled the AIR system... and thats helped clear up things.
Old Dec 14, 2004 | 07:49 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
The 2.8 for starters...
Old Dec 14, 2004 | 07:53 PM
Engine: 355 TPI
Its in the works, but not an option at the moment
Old Dec 14, 2004 | 07:55 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
the a/c and a/c lines. for starters
Old Dec 14, 2004 | 07:57 PM
Engine: 355 TPI
Crud shoulda mentioned that too.... I got rid of that as well...
well heres a pic of the bay, so u can see whats up with it.
Old Dec 14, 2004 | 08:34 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Holy crap! A CArb! No wonder it's a crowded mess But really. Get rid of all the pollution control crap, A/C and that's about it.
Old Dec 14, 2004 | 08:47 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Find a 3.4 block, get the Edelbrock 4bbl intake for the 2.8 (it will fit fine) and remove the EGR/Smog accesories. I believe i have a pic of my engine bay around here somewhere...
Attached Thumbnails What can be removed on 2.8L engines that can help free up space-stock.jpg
Old Dec 14, 2004 | 08:51 PM
Engine: 355 TPI
my problem with the swap of a 3.4 is..... why wouldn't I just go swap in a 350? lol I had a thread on this earlier and was so confused as to what was best to do when it comes to money and time.
Old Dec 14, 2004 | 09:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The main reason is when you swap in a 3.4, you JUST swap in the 3.4 block.
350 needs new transmission, new radiator, springs, wiring, distributor, exhaust . . . blah blah blah
But a big way to clean up your current 2.8 is to hit the junkyard. Find an 85-up f-body that's fuel injected, and take it's electric fan and "fan shroud". The fan shroud, as you can see from Doward's pic, on an EFI motor is basically "just" an upper bracket and a lower bracket. While you're pulling out the fan and the two brackets and the "radiator cover plate", also take all the wires that connect the fan - take as much as you can of the wires, including the fusable link and the relay.
You'll also need the coolant temp switch in the rear of the passenger side head- it'll have a single green wire going to it. An easier way is to buy a new one from a parts store; buy it for the year/engine of the junkyard car.
Then junk your clutch fan and huge fan shroud, and install the junkyard parts. Hook up the junkyard wires, and you've got a cleaner looking engine compartment that should run a bit cooler.
Old Dec 14, 2004 | 10:42 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
You can relocate a lot of components where they are less noticeable...for example, relocating the charcoal canister under the battery tray area, or moving relays where they are less obtrusive.
Old Dec 15, 2004 | 06:08 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I've seen that a 3800 swapped in can cut down a lot of clutter
Once everything is cleaned up, and looking "factory fresh" it'll just be that much better. Also, if you have the time, on the pass side along the fender I undid the wheel well liner & rerouted some wires so that they pass unseen to the battery. Looks really good & cleans up that side. I still haven't finished my a/c delete box ( ) but that also cleans up the engine bay a lot (however, w/my swap it would've been better to keep it & hide the pcm in it)
Old Dec 15, 2004 | 06:50 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
project, post some pics of your swap? Its been 6 months or so now?
Old Dec 15, 2004 | 07:35 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Get the Edelbrock 2bbl or 4bbl manifold, aftermarket carb, and remove the ECM and all related wires to the harness. Do a search in the V6 forum for a guy named Ghostrider84. He removed a bunch of stuff from his carbed v6
Old Dec 15, 2004 | 12:08 PM
Engine: 355 TPI
Oh sweet thanks guys for some of those tips
And I will be searching for ghostrider, thx mdv6
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
kah992
Aug 19, 2015 02:55 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
