Finally found what made engine die...
Old Dec 18, 2004 | 04:56 AM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
It wouldnt run even in idle.Took advice and replaced the ignition module.Car ran, then I got a 54 code.Traced it to a bad oil pressure switch as well.It seems I had multiple trouble at one time.Go figure.Since my 91 is out of the range for emission testing in my state(NC),can I gut the catalytic converter or run a straight pipe for a lillte power or does the 3.1 need backpressure from the cat to perform better?
Ken
Old Dec 18, 2004 | 05:16 AM
oil pan 4's Avatar
Car: 89 Firebird
As far as back pressure my 2.8 and step dads 3.1 camaros our cars liked a full exhaust with a cat and no muffler (my step dads car when the muffler rusted off) or no cat and a muffler(my car).
Old Dec 18, 2004 | 02:23 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
'91 is out of the range for emission testing in nc. But, they still are supposed to do a visual inspection. You would need to gut the cat, and leave the shell so it looks like it is ok. You also can't run without a muffler here, or with a cutout. Or find a shop that does a 5 second inspection.
Old Dec 18, 2004 | 02:43 PM
Kååre's Avatar
Car: trans am and hybelwagen
Engine: 350x2
Transmission: auto
I don't think any motors need backpressure, what they need is velocity, and that could drop of if you go with too large pipes. Some call it backpressure, but it really isn't.
Maybe your exhaust is clogged, I had a dead rat in mine once, real ewey smell.
Old Dec 18, 2004 | 05:49 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
trust me these 3.1/2.8s sound like crap with straight pipe's
we got a 91 firebird in at work last week and its loud but dosnt sound at all powerful
it had a custom straight pipe
think of how many ***** cars sound thats how it sounded but much louder
pull the cat but keep a muffler of some type on there
these engines do like some back pressure
and besides they sound better aswell
Old Dec 21, 2004 | 10:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah that whole "engines need backpressure" is just one of those myths; don't even worry about it. The motor will run OK without a cat. In fact if that's the factory cat, the catalyst bed might be breaking up and clogging the exhaust.
But a new hi flo cat is $100 from Summitracing.com ... that's got my vote.
Zachattack0925
Aug 12, 2015 09:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
bjpotter
Aug 12, 2015 06:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
antares57
Aug 6, 2015 07:47 AM
