Cmaro Vs. Firebird motor differences...
Old Dec 29, 2004 | 07:56 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
I swapped a 2.8 camaro motor into my firebird. While driving it around I get a couple of problems...1) Check engine light comes on after driving for a while and car is fully warmed. (It is egr related but don't know why. Previous motor; light never came on for egr. Swapped over old egr still comes on. Put in new BOSCH O2 sensor. Redid my plastic hoses on manifold area. Could exhaust leak be the cause? 2) Rad fan turns on with car. I couldn't get my rad fan to turn on at all with old motor. Didn't some camaros have 2 fans and one ran continually? Any sensors that are Firebird specific that I should change over?
Old Dec 29, 2004 | 08:32 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the only differences between engines of the same year should be the camero better intake.
Old Dec 29, 2004 | 08:53 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
It should all be the same except for the intake up front.
the dual fans came on the v8 camaros. Now if one ran all the time, I dunno.
Old Dec 29, 2004 | 11:20 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
no differences, they are both chevy made engines. so its the same thing excpet the intake(dual snorkel was much better).
did you swap the ecm with it?
Old Dec 29, 2004 | 11:27 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
3 1/2 year membership: $0
3275 posts: $0
2 motor swaps: $1500
Originally posted by Project: 85 2.8 bird
camero
.... priceless.
Old Dec 29, 2004 | 11:59 PM
CamaroManMike's Avatar
Car: 1985 camaro
Engine: 2.8 MPFI
Ya my 85 2.8 in my camaro after awhile check engine light comes on and I have absolutely no problems with the engine.
Maybe it is a fault that many had? like the leaking rear hatch?
Old Dec 30, 2004 | 06:03 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
As long as the car runs fine, mileage hasn't gone down and over all the car seams great. I ingore them idiot lights.
Old Dec 30, 2004 | 10:20 AM
Engine: 5.7 / 7.4
3275 posts: $0
.... priceless.
Old Dec 30, 2004 | 11:24 AM
Dale's Avatar
Engine: 350 S-TPI
thats cause he drives a lowly bird
j/k
Old Jan 4, 2005 | 11:36 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Re: Cmaro Vs. Firebird motor differences...
Originally posted by sixbanger
I swapped a 2.8 camaro motor into my firebird. While driving it around I get a couple of problems... 2) Rad fan turns on with car. I couldn't get my rad fan to turn on at all with old motor. Didn't some camaros have 2 fans and one ran continually?
As stated, only V8 f-bodies came dual fan. Did you delete the A/C when you did the swap? If so, there is a 2 wire connector that goes to the A/C line above the pass fender. This connector goes to a normally closed switch in the ECM. When this connector senses pressure in the A/C line, the ECM turns the fan on. If this connector is unplugged, the open circuit causes the switch to open and the fan to go on. So you either have to plug this connector back into the A/C line, or cut the plug off and tie the two wires together.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
E Rod
Aug 28, 2015 05:17 AM
Elliswon
Aug 10, 2015 12:33 PM
