I have read that some early third gen v6 cars did not have a power steering cooler. Which years didn't have the cooler, and does anyone have any pictures of how the lines were run. I appreciate any info.
cooler? This is news to me... My '90 V6 didn't have a cooler on it. Now I'm curious too!
Aaron R.
close
- Join DateOct 2004
- LocationMissouri
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1985 Z28
- Engine305 LG4
- TransmissionT5
- Axle/Gears3.42
- Liked:316 Times in 215 Posts
My '87 has the cooler. I might be able to get some pics, but I'm not sure how long before I can get them developed...
EDIT: do you need pics of the cooler lines or pics of a setup WITHOUT the lines?
Aaron, I need pics without the cooler, but thanks anyways. To clarify, it's not really a cooler, just a hard line that runs under the radiator to allow air to pass over and "cool" it.
EDIT: here is a picture for reference
https://www.thirdgen.org/techbb2/sho...hreadid=263120
I've got that cooler - but I don't know if it's actually hooked up!
My '92 has one. I all ways wonder what it was. I see it every time I go under the dar to change the oil but never looked to see ware it connected to.
Thats one lame cooler. I have it, most have it.
Not sure id even worry if you do or don't.
its pretty cheesy as a cooler. You could make one like it for pennies.
Anything with steel lines can be called a cooler now I guess.
gas lines, tranny lines, brake lines. Them little curly cue coils near your master cylinder are coolers too.
Quote:
I'm curious too. How are the lines run on cars without the, so called, "cooler", and which ones didn't have it? Originally posted by 25THRSS
Quote:
I always wondered what those curls in the brake lines were for.Originally posted by Gumby
Interesting, my 85 doesn't have this. I wonder what the RPO codes (if any) are for these things.
Quote:
I'd heard that they were supposed to reduce the chance of the metal tubes flexing, fatiguing, and cracking, since the m/c was mounted to the firewall, but the tubes went near the suspension. Never thought about them being there for a cooling effect tho!Originally posted by bru333
As to the p/s cooler, I've got one, if you don't, get one from a junkyard for $5. "Might as well" But I wouldn't go crazy trying to make it cool better or anything.
