Everyone, the theory is cracked!
Old Jan 2, 2005 | 12:38 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
I had an older post going about deleteing the ac compressor, and many people had said to just re-route the belt to a non AC. The routing is there, however the belt will not fit! Way to small. Something is different somewhere, not yet sure where though. Maybe someone of greater knowledge will know. I think an A/C delete pulley must be used. However not sure if the v-8 ones will fit What you guys think
Old Jan 2, 2005 | 01:46 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
https://www.thirdgen.org/techbb2/sho...hreadid=272470
Go back and read the answer to your other post...vsixtoy gave you the part # for the pulley...
Old Jan 2, 2005 | 02:43 PM
Engine: 2.8 Lt
Transmission: 5 Spd
I knwo he did. however like he said it is a V-8 one, so the mounting is different I looked into it
Old Jan 2, 2005 | 03:03 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
it fits, you mount it upside down or sideways or something. You can use it for an a/c del and supposedly smog pump del.
Old Jan 2, 2005 | 03:05 PM
bru333's Avatar
Car: 1987 Camaro SC
From the other thread...
quote:
Originally posted by camaro350man
Yeah but, isn't the way it mounts different then the v-6?
Yes, but it works identical. It just on the opposite side of the motor and it mounts right side up (not upside down like on my truck)
Old Jan 2, 2005 | 03:08 PM
Engine: 2.8 Lt
Transmission: 5 Spd
I apoligize, i will look into a little more, probably get one off of ebay then. But the main point of this post was to tell people that u can NOT re-route the belt. Maybe if you get a custom size belt, but still not sure
Old Jan 2, 2005 | 07:13 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
you can either get a delete pulley or get a belt made for a non-A/C serp system. it would probably be cheaper and easier to just get the belt though. mine has no A/C and i do not need a delete pulley
Old Jan 2, 2005 | 09:34 PM
Engine: 2.8 Lt
Transmission: 5 Spd
I was told you still can't get a smaller bet because it will throw off the belt tensioner The non ac cars are differnt.
Old Jan 2, 2005 | 09:50 PM
bru333's Avatar
Car: 1987 Camaro SC
Re: Everyone, the theory is cracked!
... The routing is there, however the belt will not fit! Way to small. Something is different somewhere, not yet sure where though. ...I was told you still can't get a smaller belt because it will throw off the belt tensioner. The non ac cars are differnt.
The Parts America web site lists a smaller belt for non a/c cars. I guess I'll get a smaller belt and see for myself. My a/c doesn't work (compressor leaks) and I've been thinking about just taking it off.
OH! you have a 5 speed...Do you still have a smog pump? If so did you try an 86" belt. The belt for no smog pump is 81.5"
Old Jan 3, 2005 | 06:57 AM
drdave88's Avatar
Engine: 6.0L
what is different about them? as far as i know, the crank, waterpump, alt, and p/s are all the same. the only difference would be the a/c. taking that off would just require a shorter belt. if there is something different id like to know though
Old Jan 3, 2005 | 09:12 AM
Engine: 2.8 Lt
Transmission: 5 Spd
I was doign some research and was told by someone that the power steering has a different bracket, I do not know the truth to this. I was also told that the belt tension will be screwed up if you just run a shoter belt. Again not sure on any of this. There has to be something different because it doesn't make any since, something has to be slightly different. Maybe somone will help out here.
Old Jan 3, 2005 | 09:16 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The one nice thing about having an 86. I have that in between year belt system. I just remove the belt n toss it. It didn't run anything its self.
Though I needed a smaller belt to delete my smog pump.
Old Jan 3, 2005 | 10:09 AM
RedTtop5spd's Avatar
Car: 99 SS
That's what I like about my 85. What I didn't like was that once I deleted the smog pump my car went from eating a properly tensioned belt in 9-12 months down to eating one in 3-5 months. Finally fixed the problem the other day. (Who says kicking your engine doesn't fix anything?)
Old Jan 3, 2005 | 12:30 PM
Engine: 2.8 Lt
Transmission: 5 Spd
I like the serp. belt
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
