Does a 2.8L have a map???
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Does a 2.8L have a map??? Code 33!
Ok after more research I see the 2.8L MPFI does not have a MAP. That leaves (according to the code chart) "low voltage at the MAF. I've done all the tests I know to test the MAF--shows good.
What's the deal?
HELP!
What's the deal?
HELP!
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Low voltage for maf == low frequency. The code is set when the maf is sending under 2hz. A major vacuum leak, crack in the intake tract after the MAF, etc, can easily set this code. If all else fails, check for faulty wiring (shorts, grounds, breaks).. you can test the MAF with an oscilloscope if you have one, though I'm not sure what the stock airflow tables look like, so I can't readily convert cycles into gm/sec.
The MAF is probably bad.
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Check the connector at the relay. This is where my problem was. I assume it was once covered with dielectric grease, but after 18 years enough crap had built up in the grease that it was causing a bad connection.
Car: 1989 IROC Z-28
Originally posted by FbodTrek
You got codes Zap? Or is it running like crap?
Hey Dude I should have known I'd run into U here. If I had your phone #, I would have called U!
32 33 45
see other thread I posted on here "Have to give it gas to start"
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
I know with mine you have to let the fuel pump prime up or it takes a while to crank. These are finicky motors Craig, problems can be hard to find (I should know). Oh yeah, when's the last time you changed the fuel filter?
