Have to give it gas to start???
Old Jan 2, 2005 | 02:47 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
On my wife's 87 RS--2.8L/700r4, we always have to give it gas (press the gas pedal) slightly for it to start--can't figure it out. Once it starts it runs/ idles fine.
Checked,and/or replaced and/or adjusted following with no difference:
complete ignition--plugs,wires, cap, rotor, coil, timing
MAF
EGR Valve + operation
TPS (.50)
IAC
vacumn leaks including intake vacumn level with meter
Ox sensor
Cat not plugged
?????????HELP???????????
Old Jan 2, 2005 | 04:34 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
it has a version of a map by the egr solinoid. Iferget what it's called, but I'm sure someone will chime in w/the exact name. It has about 4~5 wires to it & a vacuum tube going to it.
edit: oops, wrong thread, but same thread starter
Old Jan 2, 2005 | 04:43 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
I found that-- has 4 wires--went to Oreillys auto parts--had no such part.
Any one know what it is called or the electrical values to double check it
Old Jan 2, 2005 | 04:48 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
what about the cold start injector not firing, which is opposite of what normally goes wrong with them.
Old Jan 2, 2005 | 05:39 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Did you clean out the throttle body? It gets a lot of crud in it on the back side, where you can't see it, from the egr. Could be blocking the IAC passage.
Is this only when cold, or at any temperature.
Old Jan 2, 2005 | 05:57 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
I know I'm really showing my ignorance here, but what is that?
Old Jan 2, 2005 | 06:05 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Done only few months ago--the problem has pretty much been there since we bought the car several years ago.
About the only time it will start is if it within a minute or so of being shut off.
Cleared the pooter (ECM) jsut replaced ox sensor and fixed vacumn line and checked EGR for the 32 + the 45--seems to have gone away. and still getting a 33, but it takes a while before it throws the code. Could that have anything to do with it? (Actually this should go in another post about this car) see below
Any one know what it is called or the electrical values to double check it?
reply:
Old Jan 2, 2005 | 06:12 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
TPS voltage should be .54-.56, btw...
Cold start injector is a valve at the back of the intake manifold which opens during cold starts to richen the fuel mixture (it isn't handled by the ECM, like 88+ cars)
Cold start injector is wired to a switch that sits next to the coolant temp sensor. CTS is yellow and black wires, other is the cold start switch.
Old Jan 2, 2005 | 06:14 PM
TechSmurf's Avatar
Engine: LS1, Scrap
The 4-wire single-vac-port vaccum switch they're referring to is the EGR diagnostic switch.. it just tells the ECU when the EGR system is operating correctly. It is not a MAP, but is what's triggering your EGR code if it's unplugged or leaking vaccum.
Old Jan 3, 2005 | 09:15 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
THANKS for the info guys.
I'm pretty familiar with my 89 IROC, but not so much with my wife's 87 rs.
Cleared the codes after repairing the vacumn line on EGR and replaced ox sensor. Will see if the 33 comes back. I checked the MAF and it seems ok and does not have any "symptoms" like one might expect.
Thanks again.
Craig
jklein337
Sep 19, 2018 06:23 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mdtoren
Aug 23, 2015 12:52 PM
wayshegoes
Aug 17, 2015 12:00 PM
mdtoren
Aug 16, 2015 05:45 PM
