pacesetter headers for v6???
Old Jan 4, 2005 | 02:56 AM
kal's Avatar
kal
Car: 1983 Firebird
Engine: 2.8L-5.0 swap
Transmission: T-5 5 speed
I was reading about the new pace setter headers and was wondering why they are olny listed to fit the 85 and later f-fodys. Why arn't the 82-84 listed. Does anyone know if they would fit the earlier models. I have an 83 2.8L with a manual clutch and the olny things I can think of is that they might not clear the clutch pushrod or mabey it is because of the emission tubes. I want to het some for my car but am not sure if they would fit. I can get rid of the emmissions tubes but i just want to make sure thats all i'd have to do. Thanks.
Old Jan 4, 2005 | 03:16 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Well, pacesetter's reason is definitely the emissions, but fitment vs. the manual clutch linkage would also be a complete unknown thus far and rather iffy, since noone's tried yet that I know of.
Old Jan 4, 2005 | 05:44 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The first pair of headers clears the hydro slave. Now if the revised style does, I dont know.
Old Jan 4, 2005 | 08:34 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
His 83 has the old Z bar n push rod system, no hydraulics. Think they use it till darn near 85 or atleast part of the year 85.
Old Jan 4, 2005 | 03:35 PM
kal's Avatar
kal
Car: 1983 Firebird
pics
Here are some pics of my driver side exhaust manifold where I think the clutch linkage may be a problem. If only I knew how far how far back the headers extend compared to the stock pipes. I couldn't get a very good angle so there is a tiny bit more space then it looks like in the pictures. Maybe someone can tell if they will fit by looking at them. I really hope they will fit because to replace it with new stock pipes would be more expensive and not as much fun as headers. Oh yeah my manifolds are wrapped with insulation because they have leakes that are starting to burn my wires incase you where wondering what that was on the pipes. Thanks you guys ROCK!!!!!
Old Jan 4, 2005 | 03:36 PM
kal's Avatar
kal
Car: 1983 Firebird
pics
another angle
Old Jan 4, 2005 | 03:37 PM
kal's Avatar
kal
Car: 1983 Firebird
pics
Old Jan 4, 2005 | 03:38 PM
kal's Avatar
kal
Car: 1983 Firebird
pics
top view
Old Jan 4, 2005 | 07:04 PM
Dale's Avatar
Engine: 350 S-TPI
Yes, that will be an issue.
No headers for you
Old Jan 4, 2005 | 07:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
maybe u can switch to hydraulics
Old Jan 5, 2005 | 07:15 PM
kal's Avatar
kal
Car: 1983 Firebird
Well that sucks. I was really looking forward to getting some. Oh well. I'm not gonna switch to hydrolics because I love the feel of the mechanical clutch. Does anyone know if there are any other headers out there for us with the mechanical clutches? Or maybe I could find a shop to modify those ones by rerouting that last pipe. But I'll bet that would probely cost a lot of money. I guess it's off to the junkyard for me and try and find some used ones that are way overpriced.
Old Jan 5, 2005 | 07:33 PM
Dale's Avatar
Engine: 350 S-TPI
I belive a few people here have taken their cars to well known muffler shops and had them create headers. I belive it was several hundred dollars for it though.
Old Jan 5, 2005 | 07:59 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
well, if yo could bring your car to pacesetter, they might be able to verify fitment.. I hear the weather there is a lot better than here. I miss the mechanical clutch, reminds me of the 77 T/A.
You might be able to find an extra drivers side manifold & compare it w/a header.
Old Jan 6, 2005 | 04:28 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Just email pacesetter and ask them. They are fixing the fit problem with the larger oil filter, maybe they can tell you if there will be enough clearance for your linkage.
edit: I'd send them that third pic you posted.
https://www.thirdgen.org/techbb2/sho...hreadid=273643
Old Jan 11, 2005 | 10:47 PM
KED85's Avatar
Contact Mr. Fred Gerle for his assistance
fgerle@pacesetterexhaust.com
Let him know your concerns & also your desire for the product for your application
Thanks! For all V6ers can benefit!
Old Jan 16, 2005 | 06:30 PM
kal's Avatar
kal
Car: 1983 Firebird
Does anyone know if the revised sets are out yet or when they will be done? I think I am gonna get them anyways and if they don't fit I will just cut off that one pipe and weld in some pre bent curved pipe to get around my clutch bar. I don't think it would be too difficult to just mod one pipe.
Old Jan 16, 2005 | 06:47 PM
Dale's Avatar
Engine: 350 S-TPI
it would be more then one pipe, it would be the whole left header.
Wait tell I get the revised set in, and then I will try to duplicate the angle of your pictures.
Old Jan 17, 2005 | 12:53 AM
kal's Avatar
kal
Car: 1983 Firebird
Thanks Dale!!!!!!!!!
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
