DOWARD's fun little package...................
Old Jan 4, 2005 | 02:08 PM
confucius101's Avatar
after reading his last post
i'm really thinging about keeping my 3.1
i've picked up several parts over the past 2 years that i'm said to say are still sitting on a shelf but acording to the sumitt rep are still returnable so here we go
how to prepare a 10+ yr old motor for DOWARD's fun little package?????
when you figure most of us have at least 80 - 100,000 miles on our engines what should one do to prepare it for boost????
what aftermarket parts would you recomed for a stock motor to get the most out of the turbo?
(with out blowing anything up of course)
Old Jan 4, 2005 | 02:12 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
roller rockers
Old Jan 4, 2005 | 02:51 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
The only way to "prepare" a motor for turbocharging is to rebuild... there's very little external you can do to be sure nothing will go wrong.
But there is one major external thing... make sure your fuel system is in top notch condition. Fuel pressure check, filter replacement, etc. A minor lean condition in a naturally aspirated engine -> scrap metal on a turbocharged engine.
Old Jan 4, 2005 | 03:20 PM
ok well i figured the rebuild went with out saying but you use all original parts or would you go aftermarket????
here is a list of what i was going to origionaly do with my 3.1 and like i said i have several well almost all of these parts sitting in a closet colecting dust
Sumitt part numbers
Part # Item Price Qty Line Total Select
ACC-150617 Fuel Injectors 17Lb Set 6 $173.69
ASP-541-801 PULLEY $53.69
CLO-931-37 TIMING SET TRUE SERIES $94.95
CRN-254122 Chevrolet: 1981-89 2.8L-3.4L, 264/274 advertised duration, Compucam 2030, hydraulic, cam and lifter ... $169.95
CRN-25621-12 Pushrods Chromemoly 80-88 Chevy 60° 173 W/Cast Iron In-Line Valve Cyl. Heads $98.69
CRN-25759-12 Rocker Arms Gold Race Chevrolet V-6 80-94 2.8L/3.1L 1.6 Ratio 3/8" Stud $393.69
CRN-99848-12 1.255 in. O.D., .870 in. I.D., single, steel, valve spring set... $64.99
MSD-6200 MSD-6A Ignition Control ... $149.95
MSD-8202 Blaster 2 Coil for MSD ignitions and OEM electronic ignitions ... $28.95
PWM-57860 140 AMP BLACK ALT LATE MODEL DELCO `94-`95 2.3L `88-`92 2.8L CHEVY,OLDS $219.95
a set of Supersix ported and polished heads
and i need to come up with a larger tb
are the airbox w/k&n filter is on order for the RAII hood
Old Jan 4, 2005 | 05:56 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Wow...nice list (especially some pre ported heads...). Just re-ring her, add some clevite bearings, and anew head gaskets, you're good to go.
Old Jan 4, 2005 | 07:10 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
All of that I would advise installing on the engine expect the 17lb injectors. You will need larger.
Cam is questionable, but better then stock either way it goes.
I think just a good dipping on the pistons should be fine. Then install new rings, bearings, etc.
Can you get us pictures of the ported heads? I would like to see a professionally done set.
Old Jan 4, 2005 | 07:24 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I know this is a non-tech response, but can we please have a title that doesn't encourage one to fight a mental image???? :shrug:
btw, supersix has teh heads w/bigger valves too. A powerpack actually, that includes (I think) cam & ported intakes
http://www.supersixmotorsports.com/P...kDataSheet.pdf
Old Jan 4, 2005 | 08:03 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I'll just point out that I'm using a 75k mile engine, with just a re-ring, and new bearings.
Old Jan 4, 2005 | 08:14 PM
Dale's Avatar
Engine: 350 S-TPI
Originally posted by Project: 85 2.8 bird
[B]but can we please have a title that doesn't encourage one to fight a mental image???? :shrug:
The last I looked, the bigger valves werent an option. And for 6 bills you could get just the heads, w/o the intake
Old Jan 4, 2005 | 08:25 PM
Supermann's Avatar
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
Does installing larger injectors on a N/A engine help with preformance at all? I mean, would it be a major improvement of any kind?
Old Jan 4, 2005 | 08:50 PM
Dale's Avatar
Engine: 350 S-TPI
Not unless your ones now are very dirty or you have alot of mods. Then they just need to be cleaned, or approperiatly sized injectors installed. If you need just one size bigger you could possibly bump your fuel pressure up instead.
Old Jan 4, 2005 | 09:23 PM
Supermann's Avatar
Alright, mine is stock, but how would I go about cleaning the injectors, do I just need to run the cleaner through a tank of gas, or is there something that I should actually take apart and clean out?
Old Jan 5, 2005 | 05:43 AM
Dale's Avatar
Engine: 350 S-TPI
Take them out, send to rick jensen I belive is his name. Cruizinperformance.com? I think is the company.
Old Jan 5, 2005 | 04:37 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
How much does this cost?
Old Jan 13, 2005 | 04:06 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Wow....been a while since I posted..... Whaddup Dale?!?!?!
The 15lb/hr injectors are pintle style injectors. Prone to clogging and not very great design. Go to the junk yard and pull a set of 17lb/hr injectors off of any pontiac berlinetta or whatever 3200 gen V6 and you will have disc style injectors. They have better control over the spray and don't clog as easy. Thats what I did and it helped out alot. They are a little lower resistance, but my ECM didn't seem to mind. Plus at $5 an injector, you can't go wrong.
Old Jan 13, 2005 | 04:17 PM
Car: IROC Z
Engine: 5.7
i hope you mean baretta. berlinetta is a camaro
Old Jan 13, 2005 | 04:24 PM
Blue1989RS's Avatar
Car: 1989 RS
HAHA! My bad Yeah, one of them front weeeeel drive cars from chevy. I'm such a 'tard.....
Old Jan 13, 2005 | 10:29 PM
Doward's Avatar
I sunk like $250 into freshening up the motor.
grngryoutmyway
Oct 18, 2016 05:48 PM
no green
Mar 3, 2016 05:19 PM
Quzyle
Oct 15, 2015 03:35 PM
92projectcamaro
Sep 29, 2015 07:07 PM
