anyone know of a hydraulic roller tappet cam for the v6?
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
all of my local shops can't find one, i don't wanna go with flat tappet if i can avoid it, and i definatly want to avoid a mechanical cam.
anyone know of one?
anyone know of one?
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
You can have a custom one ground from Crane or Comp Cams... the stock '94+ 3100/3400s have roller cams...
The problem is in the oiling of them, though! From what I understand, using the stock roller lifters will cause you to starve the crank of oil.
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Re: anyone know of a hydraulic roller tappet cam for the v6?
anyone know of one?
anyone know of one?
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
Originally posted by Jerriko 3.4
This is not true and a myth at best, at least involving mechanical roller cams. I looked into this and about 20 different people over at 60degreeV6.com are running mechanic roller cams without any problems. Go over there and ask.
A roller cam can make more power, as you have have steeper cam lobes - think of the lobes on a graph - you have more 'area under the curve' with a roller camshaft.
Not to mention less friction losses
Car: 89 Iroc
Engine: lb9
ok i'm using a hi flow oil pump for my new motor. everyones been telling me to run the crane 2030 cam, sound like a good idea? if its better to run a flat tappet then i'll run one.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
it's mainly how the blocks designed that makes it so crappy to run roller lifters. If you can score the "somewhat pricey" aluminum gmpp 60* block, this oiling issue has been taken care of. I also think teh gen II/gen III fwd blocks have this improved oiling also.
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
It's not "better" to run a flat tappet... it's just a bit of a PITA to convert to roller. The reduced friction of a roller setup will free up power regardless of your cam profile.
Project 85 is right... but hey, a flat tappet works fine for us!
Also, the FWD blocks will not bolt down to the RWD platform. I am debating whether or not to build an adapter, and sell them, too.
Car: '63 Nova Wagon these days
Engine: 3.1L V6
Transmission: 5-speed
These guys,
http://www.killerbv6.com/homepage.html
Sell a "conversion kit" to use a FWD engine in a RWD application. their specialty is V6 conversions for the MGB. They like to use T5s. Not sure if it is a special bellhousing or an adaptor. might work in a 3rd gen camaro.
Frank
Frank
Engine: 3.4L 207 V6
I'm going to throw the stock 3100 roller setup I have, into the 2.8 rwd block - I'm going to repair the bottom end, but I'll probably end up starving the main bearings @ 6000 rpm. That's bad
There are no oil issues with a roller cam on the normal 2.8, 3.1, or 3.4 blocks. I verified this over on 60degreev6.
Engine: 3.4L 207 V6
Solid roller, yes. Hydraulic roller, no.
