Name this part
Old Jan 14, 2005 | 05:45 PM
Karr1986's Avatar
Car: 1986 Pontiac Firebird
Engine: 173, 2.8litre MPFI V6
Name this part
What is the name of the gasket that goes between the fuel rail and the fuel block, and where can i find one
Old Jan 14, 2005 | 05:47 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
uhhhhhh..... perhaps you should explain wtf you're talking about a bit better, because my mind just registered both items as the same item (the fuel 'block' *is* the fuel rail)
Old Jan 14, 2005 | 06:02 PM
Karr1986's Avatar
there is a small block that the fuel lines "plug" into, this is also the where the fuel pressure test connector is. This "block" (Haynes Manual calls it) Bolts to the top of the fuel rail. Between the block and the rail is a metal gasket with 2 rubber "o-rings"(lack of a better term). My o-rings on that gasket dont look so go so I want to replace it
Old Jan 14, 2005 | 09:25 PM
TechSmurf's Avatar
Engine: LS1, Scrap
(breaks out Haynes manual) Oooooohhhhh........ hmm. no clue. Sorry :shrug: Check with a dealership. They'll have tear-down images that show the part number at least.. perhaps they can tell you what it is.
Old Jan 14, 2005 | 10:02 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Tech, he's talking about the actual 'block' (entry ports) for the fuel lines, wheere they go into the fuel rail.
Old Jan 14, 2005 | 11:29 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
that piece of aluminum that has the two rubber holes in it?
yea good luck with that... lol
Junkyard is where I ended up getting my replacement. Just kept taking them apart till I got a decent one.
-Bud
Old Jan 15, 2005 | 01:11 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Yeah, looking at the haynes I figured out what piece he's referring to.. but that doesn't give me any better clue on what that gasket would be named, and I highly doubt you'll find it anywhere other than a dealership....
Old Jan 15, 2005 | 09:50 AM
KED85's Avatar
Can you access that area easy?
Sprinkle some powder over that fitting to test your theory of leakage.
Hit the wrecking yards for any similar sized "O" rings
PLUS any TRUE DECENT Parts store can sell ya a "Fuel injected" "O" ring of a certain size.
Even dealership sells those, too.
Correct, go visit the GM parts counter, book in hand.
Spend probably $5 if that much.
Old Jan 15, 2005 | 12:17 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
dealership only carrys fuel rail as complete set. All 3 parts. Is NOT cheap either.
Time to go to a salveage yard and just get all 3.
Old Jan 16, 2005 | 03:01 PM
Karr1986's Avatar
To end this thread I found out what it is. The only place that carries them is the dealer. The only way it's sold is as part of the "Fuel Block Assembly Kit" and its about $80. I got one on order but for now a little gas proof gasket sealent ($3.99 at autozone) has done the trick.
thanks guys
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
