Do you T Tops leak?
Old Jan 18, 2005 | 08:24 PM
watafo's Avatar
Car: Chevy Camaro Berlinetta
Engine: V6 2.8L
Transmission: Automatic
Do you T Tops leak?
Guys, I forgot to mention that a guy from NAPA recommended me a product to stop the annoying leaks...It is call "Silicon Compound" made by NAPA, you should rub it with a cotton rag through the weather strips, it is awesome, in my case, it reduced a 90 % of the problem. It costs around $ 13.
Old Jan 19, 2005 | 03:30 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
my t-tops leak all over me when I'm driving... and my back seats are all wet everytime it rains... I think I'll try that, or get some new stripping...
Old Jan 19, 2005 | 04:04 PM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
Mine didn't leak when I first got the car, but it has started to do so now. I've spotted that it leaks between the seal and the roof, so I'm just going to silicone it and see how long it holds up. New seals are expensive, and the ones I have really look good, only it still leaks..
Old Jan 19, 2005 | 04:13 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Odd that you should put this thread in the V6 forum, because only the t-tops on my V6 car leak!
Old Jan 19, 2005 | 04:31 PM
watafo's Avatar
Engine: V6 2.8L
Guys, I tell you......my T- Tops were a waterfall, I tried the regular silicon that you can get anywhere.......naaah .....it was the same thing......try this one, it does not become solid, it is always like gel, this guy told me that GM Dealer recommended this product for the Camaros.....pass it through all over the weather strips, also I rubbed it through the doors weather strips too., it prevents you to get sticky doors when is freezing outside. IF it does not work the first time, pass it again, in my case, it worked the first time.
Old Jan 19, 2005 | 04:37 PM
305q_ta86's Avatar
Transmission: 5 spd
*shrugs* ok, cant hurt to give it a shot..
Sounds a little too good to be true though...
xxx3man`
Sep 23, 2015 10:37 PM
mike_c
Aug 27, 2015 04:32 PM
TheExaminer
Aug 26, 2015 04:59 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
wayshegoes
Aug 17, 2015 12:00 PM
