My fuel line
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
My fuel line
Yo guys i got a problem that I hope i can get a quick answer to.
Whats the name of the nut that goes to the fuel filter housing? There is a big one and a lil one. The lil one is the one I'm going for. I need it because its stripped..
How can I make it so that I can get the fuel filter replaced? I can't take out the housing because of that rounded nut? Would I have to chop the line and use a rubber hose? I have another fuel housing from a dif 2 barrel v6 carb but it only has the big nut and no line feeding to it.
Im sorry if im too vague but im posting this in a bit of a rush, any help is appreciated.
Engine: 355 TPI
nm , i got some help at o'reilly's today and picked up this lil nut that sleeves into the housing and has an extension coming out to hook up a rubber fuel line.
Engine: 355 TPI
Ok, so I do need a lil bit of help from you guys
I hacked the line and the new fitting and filter are in. Like a breath of fresh air (or gasoline
Heres my slight problem though...
the 3/8inch rubber fuel hose im using is being slightly obstructed by the EGR. I'm afraid that it might interfere with the amount of fuel going to the carb. So theres 2 things Im thinking...
#1 remove the EGR
#2 Use a line more flexible than rubber hose
While #1 is feasible, I think if there is a possibility of getting a more flexible line, i'd rather do that.
What would you guys do? Is there a such a line that would be flexible enough that you could bend it more than rubber and not have it make a kink that'll interfere with the movement of the fuel?
I need some help because I'll need to get the car running within the week and I'd like to get it done ASAP
:shrug:
) Heres my slight problem though...
#1 remove the EGR
:shrug:
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
use a longer piece of hose so you don't have to kink it. Though Id run steel braided hose if you can flip the money. Especially around hot engine parts.
Engine: 355 TPI
Would the fuel pump have a hard time getting fuel to the carb? Since it needs to travel a longer distance than the hard line did and has to move upwards before it can level out and go to the carb. I don't want it to die of fuel starvation (but I hope I don't sound like an idiot either lol)
Is that steelbraided more flexible or possibly thinner than the rubber hose? Cuz for 3/8, thats just the middle part. The actual hose is pretty thick
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
No your fine. a few extra inches wont make any difference. Your better off with it a little longer then kinkin it off.
Steel braided isn't as flexible, per say. Its just regular hose with steel around it. Protects it from heat n wear.
Car: Chevy Camaro Berlinetta
Engine: V6 2.8L
Transmission: Automatic
hahaha, that was my first mistake in my car......I fixed it by replacing the pinched fuel line with a rubber hose right to the fuel filter, two clamps and that is it.
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
If you want you could take the fuel filter out of the carb and put a inline fuel filter in the middle of the hose should give you some more room to work with. Also i heard that it will give tyhe carb more gas. I am curious if this is actuly true or not someone let me know.
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
