Cool Cans?
Old Feb 17, 2005 | 06:40 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Cool Cans?
Does anyone actully have on of these or tested them out? How do they keep the fuel cool? Where do they mount? Worth it? Why is it rare to see one of these on a car?
Old Feb 17, 2005 | 07:59 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Re: Cool Cans?
Originally posted by V8 Slayer
...How do they keep the fuel cool?..
You have to fill them with ice.
Old Feb 17, 2005 | 08:26 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
they are mostly used on circle track cars
Old Feb 18, 2005 | 03:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Plus as far as I've known (haven't seen one up close), you'd have to get tricky with the fittings to use it on a fuel injected motor.
Old Feb 18, 2005 | 04:19 PM
Car: IROC Z
Engine: 5.7
the one that i saw just threaded into the fuel line, and was basically a coil of fuel line in a chmpaigne cooler
Old Feb 19, 2005 | 03:03 PM
BitchinRS's Avatar
I have also seen ones that mount to you frame rail and is rectangular in shape with cooling fins. No ice required
Old Feb 20, 2005 | 12:18 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, "just"... I assume the cool can uses AN fittings, and the factory fuel injection uses metric fittings ... did ya see this on a carb'd car or a FI car?
Old Feb 20, 2005 | 12:29 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
really doubt your going to see much improvement with them though
might be wrong but I doubt it is goign to make that much difference
Old Feb 20, 2005 | 09:12 AM
Car: IROC Z
Engine: 5.7
it looked home made, i dont know what fittings was on it. it was on ebay.
Old Feb 20, 2005 | 11:11 PM
oil pan 4's Avatar
Car: 89 Firebird
Most of the ones I have seen have pipe thred fittings going in them.
But you can stick AN fittings on those pipe theded in and out lets.
By no means a bolt in mod.
Fill it with dry Ice.
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
Leggman1
Aug 6, 2015 04:15 AM
