Oil Pressure gauge went crazy!
Old Feb 22, 2005 | 07:11 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Was at a stoplight today coming home from school and I glance down at my oil pressure gauge and its going nuts! Instantly jumping from about 40 to 80 and back and forth....I pulled over right away just to check under my hood.Got back in and drove away and everything was fine...WTF...
Old Feb 23, 2005 | 08:06 AM
KED85's Avatar
I'd say two things
Either low oil level
or
Oil pan sloshing, meaning the oil went away from pump pick up & then came back.
This pan does not have the "baffles" like a V8 pan.
Old Feb 23, 2005 | 10:59 AM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
What do you mean it "went away from the pickup"?
Where did it go?
Old Feb 23, 2005 | 11:57 AM
KED85's Avatar
Think of ocean waves coming onto shore then going away.
Oil went away from your oil pump pick up screen (upon stopping) then oil came back (when resting at light) to pick up screen.
Old Feb 23, 2005 | 12:07 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Hi, I'm new to the board, but my 1989 2.8 had the exact same problem. It went from the usual 40/60 to about 80, then went back down. Never went down to zero, but it happened while driving and while at a stop. Turned out to be the oil pressure sending unit, a fairly cheap fix. But yeah, I think all those other things should be considered too
Old Feb 23, 2005 | 03:20 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
I've had problems with the oil pressure gauge on my '87 Camaro w/ 2.8L. It was the wire for the oil pressure sending unit (sensor). It would loose contact sometimes and the gauge would point straight up (way past 80 psi).
Replaced the connector on the wire and it was fine.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
