Front view of a 2.8L v6 engine.
Old Mar 7, 2005 | 06:29 PM
Pajaro De Fuego's Avatar
Car: 1989 Firebird SSA
Engine: 2.8L V6
Transmission: The stock one...lol
I need a picture of the front view of a 2.8L v6 engine. I need to check something with my own engine...
Old Mar 7, 2005 | 09:58 PM
j_camaro_67's Avatar
Car: dark hunter red 84 camaro
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
if u go to https://www.thirdgen.org/techbb2/sho...hreadid=281195 there is a 2.8 engine. i will get one of my car and send it to u
Old Mar 7, 2005 | 10:02 PM
Engine: 2.8L V6
Thanks, My engine looks way different than that...that black hose thats coming from between the colored parts is hanging at the bottom of the engine. Hmm, I am missing my smog pump... Know where I would go about finding one? for an '89 firebird.
Old Mar 7, 2005 | 10:32 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
looks different because that's a carbed v6, u need a fuel injected model. Should be able to find some in the search.
Old Mar 7, 2005 | 10:41 PM
Engine: 2.8L V6
Oh, haha. Ok I tried googling it...no luck.
Old Mar 7, 2005 | 10:48 PM
85f-bird's Avatar
Engine: 2.8L, LS1
here's a link that has some pix of engines in it.
https://www.thirdgen.org/techbb2/sho...engine+%2Bpics
that should help you out
Old Mar 7, 2005 | 10:57 PM
Engine: 2.8L V6
Thanks, that did help me.
Old Mar 17, 2005 | 06:47 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hmmm, Pájaro de Fuego is = Bird of Fire (or Firebird?)
Old Mar 17, 2005 | 08:37 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
riddle me THIS
Old Mar 17, 2005 | 11:30 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Originally posted by Project: 85 2.8 bird
riddle me THIS
We gotta talk
Where did you come up with that tensioner mount and positioning? It's what I need for my electric waterpump function so I am wraping the belt around the crank pulley enough to prevent slippage.
I happen to have that same steering pump bracket sitting on the new motor right now from the '94 4th gen so I am covered on that. My alt position doesnt matter much being in the stock position because the angle from the tensioner you have up to the stock alt position will work.
Old Mar 18, 2005 | 04:55 AM
Engine: 5.7 / 7.4
that's teh 3.4 I had inthe bird. Dale has what's left of that engine ( he changed out prety much everything). I didn't worry about having the engine look exactly like the 2.8, si I figured oit the a/c bypass rout & took about 6 belts to find the right length. I have it somewhere on this board,...somewhere.
So basically, tensioner mount & positioning are stock location. and yeah, that empty a/c space looks like it just begs for a s/c doesn't it?
Street Lethal
Apr 30, 2019 12:14 PM
Quzyle
Oct 15, 2015 03:35 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
buckshot63
Sep 10, 2015 09:15 AM
Ward
Apr 26, 2001 09:33 AM
