TPI fuel pressure regulator
Old Mar 12, 2005 | 04:51 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
They would work on 3.1's correct? Would 45 PSI work on a 3.1 with full exhaust? or would it need to be more,like 47-48?
Old Mar 12, 2005 | 07:06 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
The tpi regulater will work with the 3.1 dunno about the fuel pressure tho
Old Mar 12, 2005 | 07:07 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
My friend has an 89 TPI 305 and I could just use his regulator and gauge.Im not too sure what to bump it up to though,if to do it at all
Old Mar 12, 2005 | 07:09 PM
oil pan 4's Avatar
Car: 89 Firebird
It's the same part for V6 and TPI.
Here is my fuel page, it has the FPR that I used on my V6 with the summit part # too.
The stock fuel pressure is 43.5psi, turn it up if needed.
Old Mar 12, 2005 | 07:13 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
To 45 PSI?
Any other modifications to pumps/injector/rails needed?
Old Mar 12, 2005 | 09:39 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Turn it up as high as you can until youare blowing black smoke out the tailpipe, then turn it down a notch below that until it stops.
Old Mar 13, 2005 | 05:32 AM
oil pan 4's Avatar
Car: 89 Firebird
All you need is to put it on there and turn it up untill you run lean then you will need new injectors then a pump as some point. Maybe not with with a V6.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
