3.1 rwd problems after rebuild and cam install (comp 260H)
Old Mar 15, 2005 | 12:33 PM
mieta's Avatar
Car: Camaro 1990
Engine: 3.1 v6
The engine does not idle but with revs (2000 and up) smoothly. After break in the engine worked ok (bad idle, almost stopped at lights) but after ECM reset hasn't idled at all. The timing was set at about 25 btdc to get the engine working (ECM change it to even more maybe 30).
Any ideas what could be the problem?
How much btdc you have with your aftermarket cams, is 25:ish normal at all?
Thanks for advance
BTW the car is -90 camaro
Old Mar 15, 2005 | 05:25 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
is that w/ the EST disconnected so its base timing ? stock setting is at 10 degrees, im not sure what youd have to run w/ that cam, maybe 12ish? if you havent set timing w/ that disconnected, that could very well be your problem.
Old Mar 15, 2005 | 09:35 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
how big of a cam did you go with? after i installed my cam, my car didn't idle very well for a while either. with a little time, the computer adjusted and now it idles fine. i think i show about 27-28* timing with the EST wire plugged in.
Old Mar 16, 2005 | 01:00 AM
mieta's Avatar
Car: Camaro 1990
Engine: 3.1 v6
Thats 25* with EST off, with EST the ecm set the timing over 30*
Old Mar 16, 2005 | 06:45 AM
drdave88's Avatar
Engine: 6.0L
id say back it way off, like to 12 or so and try it around there. 25 degrees advance is waaayyyy too much.
wait, did you mean you have to have it at 25 to get it running or you did that when you started it b/c of the new cam? if its just b/c of the cam, back it off. if you did it because thats the only way it would start, somethings not right. did you replace the timing chain when you did the cam? are you one tooth off on the dist?
Old Mar 16, 2005 | 07:55 AM
Car: 91 Camaro
a tooth on the dist. won't matter cause that's the same as turning it. you can go with more than 12 degrees, too. like he said, if it'll run with less, it'd try less but maybe still 14 or 15 or so. what is the duration on that cam? i tried to look it up but i didn't find the 260H V6 cam.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
