max RPM?
Old Mar 20, 2005 | 05:26 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
max RPM?
what is the highest RPM you guys and girls run your 60* v6s at (specifically 3.1s)? if anyone has FACTS on what rpm stock crank and rods can handle, that's more than welcome but i'd like to hear from experience mainly. i'm curious if i'm riskin it hittin (not maintaining) 7.5-8k on my motor...that's why i'm askin.
Old Mar 20, 2005 | 05:28 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
5500
camarors8992's Avatar
Car: 92 camaro RS
Engine: 3.1 V6..stock exept v8 intake
my motor is completely stock and ive taken it a little past redline a few times
Old Mar 20, 2005 | 05:29 PM
Car: 91 Camaro
well, i'll run 6,000-6,500 without thinkin twice about it. i'm just wondering if i'm pushing my luck at over 7k.
Old Mar 20, 2005 | 06:55 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i recall reading somewhere on here that doward said these stock bottom ends are set up to run 7000 easily. but im not sure what post it was. i would imagine your top end setup wouldnt have a problem so you might be alright. interesting to find out what they really can handle, modified or stock though. it is definetly more than 5500 though.
Old Mar 20, 2005 | 07:05 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
these motors can handle 7000 rpm, and yes i've taken it that high a few times
Old Mar 20, 2005 | 07:12 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
I cant go above 5500....
Old Mar 20, 2005 | 07:13 PM
Car: 91 Camaro
i've had my tach past the 7000 that it goes to but i don't know exactly how high it was. i need to do it with the datalogger hooked up and see what it says. i don't plan to run it up at 8000 very often or anything but it gets there so quickly now...
Old Mar 20, 2005 | 07:39 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
GM itself claims the stock components of a 2.8/3.1 will spin up to 7k fine. so i would guarantee that you are fine in the 7k range and probably fine up to 7.5k or so,
Old Mar 20, 2005 | 09:47 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Incorrect - the bottom end WILL handle 7000rpm blasts.
The valvetrain, stock and worn out, will not
Upgrade the valvetrain, and have a camshaft/intake/heads/exhaust that will feed the motor there, as well
Also, I've had mine up to 6300rpm a couple times
Old Mar 20, 2005 | 09:57 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I have hit just below 7k before after about 6000 RPM there is a major dropoff in power.
Old Mar 20, 2005 | 10:09 PM
Car: 91 Camaro
doward, you know what i've got in my motor... i'm refering to mine, with the new...um...yeah....its on there.
Old Mar 21, 2005 | 06:09 AM
Doward's Avatar
Heck yeah... the only thing is, I think you'll hit max power with that cam, around 6300rpm Shift at 6600-6800rpm?
Old Mar 21, 2005 | 08:46 AM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
I have had it up to 5500 and the motor wines like crazy, I don't want to blow anything
Old Mar 21, 2005 | 10:48 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
i get kinda parinoid with the different colors on the stock tach so i have only had it up to about 5800 once or twice
Old Mar 22, 2005 | 12:47 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
I've wound the 3.4 to 6800-7000 a few times... but it's all aftermarket valvetrain... The 60* configuration makes it a really balanced motor I was told (high rpm, with little vibration).
RedLeader289
Sep 23, 2015 06:50 AM
wisemanz28
Sep 20, 2015 01:26 PM
R13_Braz
Sep 18, 2015 05:00 PM
Stroopwafel
Sep 11, 2015 06:38 AM
