VSS differences?
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
VSS differences?
Hey guys, I found a 140 mph speedo in the junkyard, but the problem is, I wasn't able to get the VSS for the car (engine/tranny pulled).
When I look up the VSS for an 89 Formy, I get 3 different p/ns, what's the difference between the 3 VSS's?
This cluster is going into a car w/o an electronic speedo w/ 3.45 gears, so I need to get a VSS.
Can I go to the junkyard and take a VSS off a V6 car? (3.42~3.45) isn't it?
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
how hard is it to get an IROC cluster to work with my 2.8 that currently has dummy guages? In the rare case that I actually find a cluster
Car: check
Engine: check
Transmission: check
Re: VSS differences?
While there get a 4-out buffer box. That will be required to convert the VSS A/C signal to a digital signal. The outputs of the buffer box will go to the speedo, cruise control, and the ECM. TBI f-bodys and some of the 87-89 MAF f-body's have them. Also Caprice in the same year range. Has '4-OUT BUFFER' on a label right on the box.
RBob.
Thanks RBob, now what I'm finding is the difference between the two 700r4 VSS's, one has a smaller shaft for <39 or a larger one for 40+.
I went over to www.700r4.com and checked the gears that I need for my application (15 drive, 40 driven).
Is it safe to assume that the 700r4s from a V6 2.8 w/ 3.42 gears would have the same gears I need (15 drive and 40 driven)
Car: check
Engine: check
Transmission: check
RBob.
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Originally posted by RBob
Not sure about the 2.8's. I know the 3.1's with an auto have 3.23 gears while the 5-speeds have the 3.42 gears.
RBob.
RBob.
I have a 92 3.1L with a 5 speed that I bought about a month ago. I was wondering if I had 3.23's or 3.42's.
Car: 95 Z28
my 2.8 has 3.42s
One of my favorite things about the car. My friends IROC has 2.11 or 2.77 *I mix those up a lot, duno why lol* but his is Posi
Numbah-1
Sep 12, 2015 08:57 PM
