Timing Help!!!
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
Timing Help!!!
my timing in my 87 camaro (2.8) was way out of wack about 10 degreeze, any way i adjusted the distributor and about 30 seconds later the timing went back to crap. does anyone know what i need to do to have this fixed??? TIA>
Car: 1987 Pontiac Firebird
Engine: 2.8lt V6
Transmission: TH700R4
did you unplug the EST connector before you started to time the car? I timed my car the other day and had the same problem and then unplugged the EST and timed it and the car ran fine.
Axle/Gears: 4.10
what doest that look like, and where is it? could you send me a picture slcustomdesigns@yahoo.com thanks
Car: 1986 Firebird
Engine: 2.8 V6
After you finish, pull the plugs and check them. I ran way-over-advanced (off the scale!) for a while once; then the fuel pump died. I changed the pump and the car wouldn't start. I pulled the plugs, and the #1 plug was destroyed!! There was no more center electrode. That's when i found out the timing was way overadvanced.
So check the plugs and make sure none were damaged.
By the way, my #1 cylinder reads the lowest out of all 6 on a compression test, so there was definately some damage done
Axle/Gears: 4.10
well, timing wasnt too bad, fixed it, car still ran like crap..... so i got pissed off and spayed a can of 2+2 down the throught (throttle body) and instantly it ran better, so i cleaned it all up and she is keepin up with the z28's next step is injectors.....
