bad motor mounts?
Old Apr 12, 2005 | 01:55 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
bad motor mounts?
My car has 98,000 miles on it. In drive at a stop light, it vibrates a lot with the a/c on. When I put it in neutural or park, the vibration more less stops. COuld this be due to bad motor mounts?
Old Apr 12, 2005 | 11:52 PM
KED85's Avatar
That sounds just about right!
I'm serious too!
IF ya wanted less drivetrain reaction like that, buy a new car.
Does wonders for problems like that!
And I'm also serious about that too.
Aged engine, underpowered engine, heavy load, vacuum leaks, all adds up to that old car feeling.
Hey IF ya got working AC & ya in Hawaii,
OHHH BOOO HOOOOO!!!!!!!!!!!!!!!!!!!!
AND if ya tell me ya on Maui, I'll be so upset to come over & solve the problem for ya!
You pay for the flight!
Old Apr 13, 2005 | 11:42 AM
AdmAnt13's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1 V6 soon to be gone
Transmission: 700r4 Automatic soon to be a T56
When I'm at a light or just stopped for that matter and I shift it into neutral and then back into drive with my foot on the brake, the car jerks forward as it switches into gear. My friends 91 V6 bird doesnt do that. His seems seamless when he does the same thing, almost like you dont notice the switching of gears. A mechanic told me my motor mounts might be going bad and that may be the cause, or something is wrong with the tranny. You guys have any clue if hes right or not?
Old Apr 13, 2005 | 01:23 PM
1989karr's Avatar
Engine: 3.4 / 5.0
I'm serious too!
Possibly bad mounts eh? Thanks, I'll look into that. Perhpas if I do that 3.4 swap! But no, sorry, don't live in Maui! lol
As far as Adm Ant, I have the EXACT same problem as you with the hard shifting into drive from neutural. Feels like you're almost gonna get whiplash! But it does not happen when shifting into reverse. Does it happen to you when you shift into reverse??
Old Apr 13, 2005 | 02:01 PM
AdmAnt13's Avatar
nope reverse is fine. Same thing as you. Great, I have bad motor mounts.
Old Apr 13, 2005 | 04:01 PM
KED85's Avatar
Open hood
Get inside car
Start engine
PUT FOOT FIRMLY FIRMLY STRONG ON BRAKE
Put in gear Drive is ok.
Give some SOME SOME gas
Then Put into reverse
WATCH ENGINE
IF ENGINE LIFTS AT ALL
Bad motor mount
IF NOT
No problem.
PS Ya screw up on this simple testing, don't blame me!
I DO MEAN keep foot ON BRAKE! and give it SOME GAS.
Old Apr 13, 2005 | 09:58 PM
AdmAnt13's Avatar
mechanic told me to do something to the same effect but i never got around to it. Plan on doing KED's test tomorrow.
Old Apr 13, 2005 | 10:02 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
How do you do it with a standard?
Old Apr 14, 2005 | 02:00 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Yup, I plan on doing that test as well! I know my motor mounts are probably the same ones that were put in there....16+ years ago........so this may be the problem! lol
Old Apr 14, 2005 | 05:02 AM
KED85's Avatar
Your question about a stick car is interesting.
I am not sure of that answer
BUT if ya gonna have car on lift I am sure they can use a pry bar for that answer.
I know this works for auto cars as I did this to my Blazer & yep bad frame mount.
On our cars it's NEARLY impossible to break metal motor mounts. Frame mounts have the rubber that wears.
Frozer!!!
Jan 19, 2024 04:55 PM
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
