3.1 vacuum
Old May 3, 2005 | 04:42 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
3.1 vacuum
doesn't anyone have the 3.1 vaccum diag search didn't help me much
Old May 3, 2005 | 10:27 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
do you need just one line, or all of it?
Old May 4, 2005 | 10:45 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
i was hoping for all of it, i just bought a "family vehicle(05 escape)" and i am going to do massive work to the bird now and i want to start with the ign sys and the emmisions and i pretty much know what i'm doing with the ign sys but have no clue when it come to vacuum lines so i am going to just replace them all if possible
Old May 4, 2005 | 12:15 PM
KED85's Avatar
Patch all lines with 5/16" windshield wiper hose.
Ya may also need some 1/4". The worst to replace is the 1/2" thick walled heater core hose by distributor base. Short section.
Do all visible hoses first. Then you will need remove the upper intake to access rest of them. Take intake & loosen, rotate, flip over toward passenger side. All stuff stays on & no need to really disconnect any hose.
Just keep patching or replace until ya done. No need to throw out every connections or plastic line as none of it is available at a dealer. And wrecking yard stuff is probably just as bad shape as your current hard plastic lines.
Use Accel products they the best in ignition stuff.
I've spent a whole day just replacign vacuum hoses & patchign the stuff. You may end up that long on the project, too. But boy is it worth it, the smoother idle and better response is great for the few dollars of rubber hose.
Old May 4, 2005 | 12:16 PM
Dale's Avatar
Engine: 350 S-TPI
Truthfully, most of them are hard-lines and shouldnt need replaced unless they got broke.
I will see if my helms manual has a diagram I can scan.
Pac J
May 17, 2020 10:44 AM
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
