A.I.R Pump on 3.1
Old May 3, 2005 | 07:42 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
A.I.R Pump on 3.1
Would a car pass semi-strict emissions tests with the air pump ripped out but the catytylic converter still on? How does the air pump come out? What else is needed to yank it out of there besides the delete pulley?
Old May 3, 2005 | 10:31 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I dont have a delete pully, just a diff belt size, and home-made alt bracket.
Bolts off below.
left wire plug laying
plugged vac line.
Kept fussing with the plug in the manifold tell I got headers
Old May 3, 2005 | 10:38 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Would it be legal with no pump but with a cat?
Old May 3, 2005 | 10:42 PM
Dale's Avatar
Engine: 350 S-TPI
dunno, im not in smog land, sorry.
Old May 4, 2005 | 01:08 PM
KED85's Avatar
Smog pumps go for about $20-$30.
Just replace it.
Loss in HP is minimal.
I too hate those A.I.R. tubes on my 85 Blazer, but not a true big deal to live with.
AND PaceSetter Exhaust is working on a header set up with those A. I. R. tubes.
Old May 4, 2005 | 02:04 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
I want to just get rid of it and gain back some power.But,I need to be emissons legal...
Old May 4, 2005 | 02:36 PM
Dale's Avatar
Engine: 350 S-TPI
unless its broke, let it be.
Gains will be so minimal for your efforts, you wont really notice.
Old May 5, 2005 | 08:05 AM
KED85's Avatar
If you ever cracked one open, you'd see why nothing is gained or lost by this pump.
It looks just like a pin wheel in a metal housing. Only pushes air.
If it works, leave it alone, keep the belt in good shape.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
