What could the problem be
Old May 4, 2005 | 05:26 PM
Loudmouth's Avatar
Car: 87 camaro z28
Engine: 2.8l V-6
Transmission: TH-700R4
I get the car up above 15 mph then when i let off or try to step on the brake i hear a chirping type sound form the car what could the culprut of my problem be and how could i fix it ?
TIA
Old May 4, 2005 | 08:48 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
squeaky gas pedal?
Old May 6, 2005 | 11:06 PM
Loudmouth's Avatar
Car: 87 camaro z28
Engine: 2.8l V-6
how do i fix the problem
Old May 6, 2005 | 11:34 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
3:1 oil. or perhaps whit lithiam (sp?) grease. if your a renagade you could even go with WD40. i would use 3:1 oil, because of the pleasing aroma.
Old May 7, 2005 | 03:32 PM
Car: IROC Z
Engine: 5.7
it may be the pedal itself, the link that makes it move under the dash, or it may be the spring on th throttle body. move the spring to wot spray, and get some in the cable too
Old May 8, 2005 | 07:53 AM
Francis T.'s Avatar
Car: 86 Fiero GT turbo, seeking right 86-88 F-bod
Engine: 2.8
Transmission: 4spd
If the sound is coming from the rear and under the car, check your rear universal. Sometimes they will make noise under different loads, I.E. braking or backing off the throttle. They can be bad 2 ways. They be lose, the bearings shot or they can be sizeed in 1 or both planes of movement. Do take a look because if it breaks, you're going to drop your driveshaft on the road somewhere and they have been know to kill people when dropped on the highway. Besides, you'll need a tow.
Old May 8, 2005 | 08:58 AM
KED85's Avatar
PULL OFF EACH WHEEL & THE BACK BRAKE DRUMS TO SEE UPCOMING BRAKE WORK NEEDED!
IN FRONT INSPECT THE BACK SIDE OF ROTORS!
Don't ask more until you tell us the results of this inspection. Because I'll bet this is where is your probable problem
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
