wierd sputter....
Old May 11, 2005 | 11:24 PM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
wierd sputter....
when i first start my car it takes a second or 2..and when it finally fires it kinda boggs out then its fine....if i go 2 move the car after its been warming up and barely step on the gas (u know like as if im in a parking lot) it'll sputter then get going....i use injector cleaner alot so...im sure they are fine..just changed cap wire and rotors...my plugs were a little white, they were gapped at .40 so i dont really think im running lean....any body have any ideas??
Old May 12, 2005 | 11:29 AM
Mr Badwrench's Avatar
Car: 88 RS
Engine: 2.8 untill the 3800 swap
Try unplugging the MAF and EGR vacuum line and see if that helps.
Old May 12, 2005 | 02:09 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
If the plugs were "white" then you must be a little on the lean side. But, I'd try an o2 sensor.
Old May 12, 2005 | 02:22 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Make sure all your wires are good, even if they are new...
Could also be the ECM. My wife's car did exactly what you
describe....it was the ECM even though it would offer no codes.
mud runner
Nov 2, 2015 07:30 PM
lanceflame44
Sep 25, 2015 12:28 PM
andy74
Sep 3, 2015 08:41 AM
Apeiron
Carburetors
Oct 18, 2001 04:54 AM
gruveb
Sep 29, 2001 03:06 PM
