what computer chip does the 2.8l use in the computer
Old May 26, 2005 | 12:00 AM
87blueracr's Avatar
Car: 1987 camaro & 70 mustang
Engine: 2.8l & built 351C
Transmission: borg warner T-5
does anyone know for sure what chip the '87 2.8l ecm uses as the prom?
Old May 26, 2005 | 12:25 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
This will depend on whether the car has had the engine recall performed or not. The PROM can be one of about six calibrations, depending on both the recall (stall and hesitation at cold start, PROMs were recalibrated for richer idle mixture) and whether the car has California or Federal emissions systems installed.
Now, if you are referring to which IC it is, I dunno...
Old May 27, 2005 | 12:50 AM
87blueracr's Avatar
not which chip the factory installed, which one that it uses if i want to go out and buy some that are not programmed and program them myself meaning what size and spec the chip is if i were to buy it from say a electronics store(i know that they would not have them but it works for hypothetical reasons)
Old May 27, 2005 | 11:10 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Yeah, I kind of figured that out last night. If I can find a way to get some of the plastic out from around the chip I might be able to expose some numbers for you...
:edit: No, I won't be messing with my current chip... I have two spares .
Old May 27, 2005 | 11:22 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Well I know worst case you can get some spares from the junk yards that can be flashed a few times. Thats what we did with mine. Quite a few computers in the 80s used the smae style/size chip! We ran thru the yards and pulled all the computers out of the cars and any computer that looked like mine we robbed the chip!
You may want to ask on the PROM board!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Damon
Sep 26, 2015 04:29 PM
