a load of questions
Old May 28, 2005 | 02:36 PM
Taylorstav's Avatar
Car: 1984 Camaro
Engine: 2.8 V6
Transmission: The one that came with the car
a load of questions
i have a few questions about my car, im just gonna get em over and done with in this post
1. My car smells like gas.....i dont see any leaks.
2. If i make a hard turn the car stalls......anyone know why?
3. My stereo keeps switching between mono and stereo, and its driving me mad!
Old May 28, 2005 | 03:28 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
1.) I'm currently running an almost stock drivetrain and I occassionally get a gas odor. I think the gas tank fuel filler neck may have a small crack -- a not too uncommon problem for certain cars.
2.) Post more on what the car is: engine, model, etc...
3.) When the stereo changes to mono, do all four speakers play the same thing or does the audio simply cut out on one wide of the car?
Old May 28, 2005 | 04:13 PM
Taylorstav's Avatar
Car: 1984 Camaro
Engine: 2.8 V6
im just kinda worried, cuz i got flamethrowers and i dont wanna put em in with a gas smell, fire+gas=not good
the car is a 1984 2.8 V6 carb.
the stereo switches to mono, all the speakers play the same thing then it goes stereo, and it startles me, and then it goes back to mono
Old May 28, 2005 | 05:43 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
WTF are 'flamethrowers'?
Old May 28, 2005 | 05:55 PM
Taylorstav's Avatar
Car: 1984 Camaro
Engine: 2.8 V6
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old May 28, 2005 | 06:53 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
1. Mine smells like unburnt gas, and raw gas sometimes. But I have no emissions, so this may be why. Also yours is carb, if I recal, them tend to smell like that at times.
2. Sometimes commen on carbs. Internal float not right, not sucking gas from propper spot in tank.
3. Install aftermarket radio if its still stock. If its aftermarket, install new aftermarket.
flamethrowers
Old May 30, 2005 | 08:58 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
i got flamethrowers
Are you kidding me???
Old May 30, 2005 | 09:00 PM
Taylorstav's Avatar
Car: 1984 Camaro
Engine: 2.8 V6
nope, its gonna be coool!
Old May 30, 2005 | 09:09 PM
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
Transmission: 700-R4
No actually it isn't going to be cool, thats for ricers, not Camaros.
Carb's always smell like gas, especially when you step on it and it uses alot of the bowl up then you get a bunch of new fuel coming you will normally smell it then. You don't want to have flamethrowers in the first place, but you DEFINATLY do not want them when you got fuel odors running around and a possible small leak, your stupidity will be your own fault when you blow yourself up and I will have no simpathy for you. Also you may not notice a leak because gas evaporates fairly fast in small quanitities compared to water, so it may be "gone" before you can see it but it will still light up if u spark it.
Your bowl may not be filling up correctly so you are taking a turn and its moving the bowl to an angle where it is getting no gas, then stalling out.
Check wiring.
Old May 30, 2005 | 09:12 PM
Taylorstav's Avatar
Car: 1984 Camaro
Engine: 2.8 V6
well im not putting it in until i get everything checked out
Old May 30, 2005 | 09:15 PM
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
Just don't put it on period.
Old May 30, 2005 | 09:16 PM
Taylorstav's Avatar
Car: 1984 Camaro
Engine: 2.8 V6
i like it, i paid for it, if i get everything checked out and its safe....why not?
Old May 30, 2005 | 09:17 PM
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
And just so you know, you wasted your money, 2 spark plugs, a simple switch from radio shack, some wire from Radio Shack, wire it into a 12v source, wire it to the switch and the plugs, hit the switch, and BAM, all for a few bucks as you can use your old plugs which arent good for running your car, but good enough for making flame shows.
Old May 30, 2005 | 09:18 PM
Taylorstav's Avatar
Car: 1984 Camaro
Engine: 2.8 V6
so what, i dont care it was like $30.......
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
If you like it, I guess go ahead but when you dont liek it you will end up with 2 hole sin your exhaust, you will probably get ATLEAST 1 stunting ticket in your life time with those on, I don't know about your area but thats aroudn $330 CDN EACH up here, quite a nice little tag for such a stupid accessory
Old May 30, 2005 | 09:20 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
dude if your car has cats you will light the whole car up. those things heat up pretty quickly, you will burn them out light them on fire and kill your wannabe camaro.
Old May 30, 2005 | 09:22 PM
Taylorstav's Avatar
Car: 1984 Camaro
Engine: 2.8 V6
insurance?
Old May 30, 2005 | 09:24 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
dude i hit the ctrl v thing dont worry about it
Old May 30, 2005 | 09:25 PM
Taylorstav's Avatar
Car: 1984 Camaro
Engine: 2.8 V6
lol ok
Old May 30, 2005 | 10:59 PM
Grizzly_Addams's Avatar
Car: 1991 Firebird
Engine: 3.1L V6 MPFI
Transmission: 4 Spd Auto + OD 700R4
I had the exact same car awhile ago. A 1984 Camaro 2.8L carb, with a 5 speed manual. Taking tight turns would make my car stall as well. It was the belt. I found out because one time I was making a sharp tight turn in a parking lot, and the belt came off the power steering pump. I was able to get it back on to get home, but I later had it replaced and never had the problem again.
Also, mine smelled like gas too, with no leaks, I just figured that's because it sucked.
As for the stereo, you probably have a short somewhere. Or, it's because it's an old ****ty stereo.
Old May 30, 2005 | 11:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL! That's been an old-school hot rod accessory that the import scene picked up on. Just cuz they were used in the Fast & Furious doesn't mean it's an import thing! The hot rod guys would just pull their choke out, which would richen the a/f mix enough to kick some gas out of the tailpipes. I guess that's what the "magic box" does with that flamethrower kit. But besides the switch and some spark plugs, you also need an ignition coil or two.
Of course he'll melt his plastic back bumper, but it's his car, not mine- and hopefully the flames won't reach the gas tank which is mounted above the muffler!
As for cutting out on a tight turn; either your gas gauge is screwed up and you're running on empty, or, you might have a sensor in your power steering pressure line that's broken. The sensor's on the 85-92 fuel injected cars, and increases the idle of the motor so the engine doesn't stall out. It might be on your 82-84 carb'd, couldn't hurt to check (it's easy to see if the sensor's there, it's right by the steering box, sticking out of a tube line.)
Old May 30, 2005 | 11:28 PM
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
yes I am Quite aware of that. But there are a few issues...
1. He isn't old school
2. He isn't a hot roddering
3. He doesn't drive an old school hot rod
4. He is doing it for ricing purposes, not for hot rodding purposes
5. In no way as of this moment in time is a thirdgen camaro considered a hot rod
6. Its stupid on a street car, hot rods aren't driven daily and put 15,000 miles on them a year, daily drivers are. One is unqiue and priceless, the other is a beater being riced out.
Old May 30, 2005 | 11:31 PM
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
Correction..
In no way is HIS camaro considered a hot rod, not all thirdgen camaros, just his at this moment in time.
Old May 31, 2005 | 01:51 AM
90camaropb's Avatar
Car: 90 Camaro
Engine: v6 3.1L
Transmission: 700r
I sure could use some flamethrowers on my moms corrolla
Old May 31, 2005 | 07:57 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
One of my friends told me Jay Leno has a rocket powered car which melted the bumper of (I think) a Diablo that was sitting behind him @ a stop light. I don't think he drives it anymjore...
Old May 31, 2005 | 03:50 PM
Taylorstav's Avatar
Car: 1984 Camaro
Engine: 2.8 V6
how the **** do u know what im doing to my car?
i came here to ask a few questions and thats it....i dont like ricers and ur jumping to all these conclusions about me and my car without knowing me or seeing my car.....my car isnt a beater, its in almost perfect condish....every mechainc marvels at the underbody cuz its so perfect...
thanks to the people that answered my questions and helped me out.
but you....if you dont like flamethrowers, thats fine, i don't care, thats respectable, but when you **** all over me and what i like and my car thats just rude. So take your snobby ****en attitude and stick it up you're ***. a real car guy respects other perople's cars. so go **** yourself.
Old May 31, 2005 | 07:39 PM
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
I respect other peoples cars that respect their own cars. If your old school why are you "fixing" up an Third Gen Camaro, that isn't old school, 50-60's is old school, there for #1, your not old school.
2. I guess you could be a hot rodder and doing **** to your car, but flamethrowers won't get that alone
3. Yah it isnt old shcool so yah
4. Ok maybe not ricing, but you have to have other things done besides a flamethrower to be considered a hot rodder, which means everyne will classify u as a ***** until you proove them different, as in most cases, people don't hop up and suep up 2.8L Camaros for hot rodding purposes.
5. Bone stock Camaro with Flamethrowers isnt a hot rod
6. Unless you want $300 stunting tickets, melting your own bumper because you dont have enough pressure to throw the flames out far enough, metling other peoples bumpers that are too close, having to pay for those damages when you do do them, possibly having your car impounded because it some places it is illegal.
Old May 31, 2005 | 07:41 PM
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
Oh and dont get me wrong, I love flamethrowers, on cars they belong on, which is few, the whole F&F scene has ruined any other cars worth putting flamethrowers on, becuase now it seems every kid wants flames coming out of their exhaust, either from running rich or from a little rich and a sparkplug, if F&F didnt exsist I'm sure it would seem alot better on rides, but now its been over used and abused.
Old May 31, 2005 | 07:58 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
wow, such cruelty. can we all just get along?
i have been ripped on time and time again for building up a V6. so, though i may not agree w/ what hes doing, or i may, its his car and we have to respect that...... unless he puts a cardboard wing on the back of it (funny story to that). i am proud of what i have done to mine and dont really care what anyone else thinks. not to brag up anyone or put anyone else down in this. just remember, we are all the ones that are made fun of at some point b/c we drive a V6. even if you have plans later on of putting a V8 in, you drive a V6 now, youre going to catch hell for it.
when i was younger, i may have made fun of him, but ive learned that we all have our own tastes for what we like and dislike. i love my V6 and wouldnt swap it for a V8 (unless its over 400hp and free, lol). i dont wanna **** anyone off, but lets just all respect everyone elses rides. remember, were all in the same boat here, same or different, were all V6 thirdgens
Old May 31, 2005 | 08:09 PM
Taylorstav's Avatar
Car: 1984 Camaro
Engine: 2.8 V6
i dont think having an old school car makes a person old school.
i know people that are passionate about old cars, and dont have one.... those people are the most old school in my eyes.
And who said flamethrowers was the only thing im going to do.....i have a list that totals about 20 grand, and finishes off with a crate engine, and im going to do it over a long time.
so this conversation is done, its pointless now
Old May 31, 2005 | 08:13 PM
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
My bad then, I can get grumpy sometimes.
Btw you shoudl probabbly put the crate engine at the front not the end , then you wouldnt have wasted the other money u spent on the things you did before the crate engine, unless its things that can be moved over then ignore me.
theshackle
Sep 17, 2020 08:26 AM
89fast5oh
Sep 27, 2015 09:04 PM
z28addict8490
Sep 5, 2015 03:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
