Throttle Position Sensor Cost
Old May 31, 2005 | 06:04 PM
KED85's Avatar
HI All
IF you have replaced your throttle postion sensor, what did you pay?
SO far I'm told for the part $45 plus tax.
That cost is for an AC Delco one from an AC Delco store that helps me with low prices.
I purchased a Bosch Oxy Sensor at $22.
The same part in AC Delco (from this one same store) was $42.
Anything I can "save" & still get correct longevity quality is fine by me
Thanks!!
Old May 31, 2005 | 06:19 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
thats about right
Old May 31, 2005 | 06:22 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
And supposedly, Bosch makes the AC Delco oxy sensors
Old May 31, 2005 | 06:41 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
$30.58 for a Standard Ignition model.
Old May 31, 2005 | 08:30 PM
KED85's Avatar
And If I may
follow up with this question
WHAT'S THE DIFFERENCE!?!?!
COULD there be ANY?
The Borg Warner Coolant Temp sensor I got sure worked perfect! And was less than the AC Delco one I just returned today.
COULD there be any true difference?
Old May 31, 2005 | 10:14 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
No, same part, should be like $25
Old May 31, 2005 | 11:40 PM
KED85's Avatar
MANY THANKS ALL for the kind responses!
Old Jun 1, 2005 | 12:25 AM
87blueracr's Avatar
Car: 1987 camaro & 70 mustang
Engine: 2.8l & built 351C
Transmission: borg warner T-5
i just got a new tps and it ran me 20$ from advance and i got a O2 sensor for about 16$ (bosch).
Old Jun 12, 2005 | 06:52 PM
bstieboydp's Avatar
Car: 1987 camaro, 1994 z28
Engine: 2.8l V6 mpfi, 5.7l lt1 350
Transmission: 700r4 in the 2.8, and t-56 6-speed in the z28
whered you get those two? i need both i have bad hesitation still
Old Jun 12, 2005 | 08:10 PM
KED85's Avatar
AH DEER PARK!!!!!!
Damn thanks for the memories!!!
I still have bucking bloody morning bucking!
And I still feel I'm getting a signal to make the TPS/ECM react incorrectly.
I have changed my Oxy Sensor to no avail.
I have one more cold sensor on the intake manifold which to change. Those last sensors next to the thermostat housing is my "enemy" Maybe.....
Hestitation is not truly related to a sensor.
That's a tune up or timing (worn out chain) issues.
Old Jun 13, 2005 | 07:07 AM
87blueracr's Avatar
i got them at advance auto. but if you don't have one near you, the local parts store should be able to hook you up pretty cheep with what you need.
Old Jun 13, 2005 | 06:30 PM
bstieboydp's Avatar
you think it would have to do with the fact that im using spark plug wires that werent designed for my car? or no, my friend bought some for his buick regal 3.8 but then sold the car so he gave them to me and i put them on, would that do it? i am eventually gonna change them out and check the distributor to see if thats it anyway
Old Jun 14, 2005 | 05:59 AM
87blueracr's Avatar
it may be, i had a problem with using a shorter coil wire that came in one of my sets of plug wires. it threw me off for a while, and the car really ran like Sh*t til i changed it out with the longer one!
Old Jun 14, 2005 | 01:48 PM
bstieboydp's Avatar
ok thanks for the knowledge im gonna pick up a set of wires anyone recommend any company and or place to go for a good set?
Old Jun 14, 2005 | 01:59 PM
KED85's Avatar
I LOVE ACCEL
ACCEL MAKES THE BEST STUFF!
LAST SET OF PLUG WIRES I BOUGHT FROM ACCEL WERE IN MID-$30s!
That was 1989!
That's right last set of ACCEL plug wires I bought was in 1989!
SINCE Accel has a LIFETIME WARRANTY on their products, I simply return them to ACCEL & in return they send me brand new spark plug sets.
Last set I got was a BRAND NEW 8.8s SET!!!!!!
Old Jun 15, 2005 | 07:35 AM
bstieboydp's Avatar
i found some accel wires for 27 shipped http://cgi.ebay.com/ebaymotors/ws/eB...category=33692 but it says 85-86 camaro v6, does that make sense? it only works for those two years? mine is an 87 thanks alot for the help
Old Jun 15, 2005 | 09:12 AM
KED85's Avatar
Myself, I couldn't understand why....
"Super Stock" Accel brand?
Yeah, that's what I started with and after one set returned, I was given the 8.8s. Even as installing one set, a boot ripped off. I used an old plug wire and again Accel sent me a new plug wire. I've sent them an old Accel coil & I gotten a new one. Once bought an old Accel Dual Point dsitributor (swap meet $10). I exhanged that with cash for a more useful distributor for my engine needs. I have a vehicle (1985 Blazer since 1989) with an over 100,000 miles on Accel coil. Accel stuff keeps working. Pay attention to wire routing and how it stays away from exhaust.
See where I mounted my Accel coil? Great choice of a spot and quick installation. Yeah & 8.8 wires, too.
9192camaro
16
Feb 3, 2019 12:21 AM
someone972
Aug 30, 2015 12:52 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
