I need gasket part # help
Old Jun 7, 2005 | 04:38 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Can anyone help me with gasket #'s for the following, I was trying tolook things up and order them from GMPartsDirect but seems they are vague on their shopping choices unless you already know the part #'s.
Need- '87 Fiero GT valve cover gaskets (GM2.8L motor)
Need- MPFI upper to middle intake gaskets (GM 2.8/3.1 motor)
Need- A/C Delco oil preesure sending unit (gauge sender, not dummy light sender)
Need- Felpro exhaust gaskets for '87 Fiero GT/ or '87 CamaroV6 (GM 2.8 motor)
Thgank you for any help, Dean
Old Jun 7, 2005 | 05:02 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
2.8 felpro gasket# (fiero style) exhaust MS93045
fiero valve cover gaskets felpro VS50077R
intake gaskets, depends on style
felpro 90454, or 90616 (not sold by self that I can tell)
from www.acdelco.com, 87 camaro with (s) 2.8l engine
15591103 for 1blade 1/8-27thread 80psi
u18010a for 1term 1/8 with light
d1818 for 2term 1/8-27 USE W/ F/PMP SW
Old Jun 7, 2005 | 09:16 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Thank you Jay. I was having the same trouble finding the upper plenum intake gaskets by themselves. I think I will just order the entire intake gasket kit from Fierostore.com.. The think that sucks is that kit has the universal Vavle cover gaskets that do not fit the Fiero Aluminum valve covers. I have to buy those and the exhaust gaskets separate there on that page link.
http://www.secureleadercom.com/fssto...Bit=3&dept=197
The first sender # is the one I need (15591103 for 1blade 1/8-27thread 80psi) I did a parts image search on the AC Delco site and it showed correctly.
The Fierostore is pricey, anone have another link that is cheaper. I have a few days to shop around some more. I would like to pick up two sets (a backup spare) of gaskets to have on hand. I am going to call summit to see if they can cross reference the gasket # for felpro and add them to my current open order.
Old Jun 9, 2005 | 05:43 PM
KED85's Avatar
Fiero Fel Pro gaskets were $12 or $17 at Pep Boys.
I got my stockexhaust doughnut gaskets from Pep Boys also, Fel Pro brand. The ones with the steel inserts.
Almost surprised you haven't bought a complete 60*V6 engine gasket set.
I also price shopped at Autozone, Kragen & Pep Boys & asked them to match some mail order places & they tend to do so, too.
Northern Auto Parts is also GREAT place
800-831-0884
Old Jun 9, 2005 | 07:56 PM
Dale's Avatar
Engine: 350 S-TPI
didnt catch this before. I buy all my gaskets locally. Autozone, Advanced(parts america) or o'rileys.
yep, sucks you have to buy the whole gasket set just to pull the top two sections of intake off. It even comes with the gaskets between heads and intake.
Some I have sold on evil bay, some I havent.
Old Jun 9, 2005 | 11:01 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
I just called and added the y pending summit racing order.
Since I have had nothing but problems with the AC Delco oil pressure sending units going out on me (3 in less than 2 years time), I have decided to go to an Autometer 80psi sending unit. I will just have to soider a screw-on type wire end in place of the factory blade style wire end feeding from the sender unit. Summit Part # ATM-2241
The Felpro gaskets were:
Exhaust manifold gasket- Part # MS90864
Intake Gasket set- Part # MS93020
Fiero Aluminum Valve cover gaskets (the ellusive rubber molded ones) Part # VS50085R
Old Jun 16, 2005 | 01:50 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
I have a felpro gasket on order, but I was driving by a local VW speedshop (TopLine racing) that I used to frequent years ago so I swung in and picked up some of the good old oversized VW exhaust gaskets I used to use on my Ghia years back.
These are the exact same bolt pattern as our heads on the 60*V6's.
Shown below are the metal ringed and papar edged backing VW type1 engine exhaust gaskets (A1 front, A2 is backside photo of the same gasket) They are 1 1/2" diameter opening- same as the PF&E Stainless steel headers Greg made for me.
The on on the far right (B) is a standard Headman headers gasket with a 1 1/4" opening and all paper. I believe the Felpro ones I have coming are also only 1 1/4" and not metal ring lined.
These were $2.50 each. Basically- any type 1 VW bug exhaust gasket will work on our motors with the same stock exhaust port and bolt pattern. The performance Vw gaskets are better for ported heads on our engines.
Old Jun 17, 2005 | 05:52 AM
Dale's Avatar
Engine: 350 S-TPI
are these felpro brand as well? Anyway you could get us a brand and part number?
Old Jun 17, 2005 | 10:34 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
I have no clue as to what they are and where he gets them. E-mail sent though- check that.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
