you guys would be happy.....
Old Jun 8, 2005 | 08:58 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
..... im now the owner of a V6 92 camaro...
local guy in the navy had to move and sell it quick.. i got it for $300
needs a fuel pump, but other then that, it runs and its in good shape.
im going to toss a fuel pump in there, charge the AC, give it a tuneup, and drive it for a bit until im sure its reliable... then give it to my sister when she starts school this fall..
any tips or anything unusual about the V6 that i should watch for?
Old Jun 8, 2005 | 09:37 AM
LT1guy's Avatar
Car: 1987 Trans Am
You might want to do a distributor rebuild if its a higher mileage car. Tom P has a good thread on it. The V6 distributor seals are bad about leaking oil, too, so I'd replace the o-ring and maybe use a SBC-style gasket, too.
Old Jun 8, 2005 | 09:44 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
mmk, i'll take a look back there to see if its leaking.. car "only" has 80k on it..
anything else? someone said something about you cant take the valvecovers off with the intake?
Old Jun 8, 2005 | 09:52 AM
LT1guy's Avatar
Car: 1987 Trans Am
Later 2.8s/3.1s/3.4s have studs that make it impossible to get the valve covers off without removing the plenum and runners...its a pain, but it doesn't really take that long to do. The only problem is the first time, because the gaskets will usually tear, so they have to be replaced.
Old Jun 8, 2005 | 12:02 PM
duranged's Avatar
Car: '88 firebird/'98 durango
Engine: 2.8v6/5.2v8
yeah, watch out fir the sides of the radiator bulging out, if they are plastic, i had to replace one side on mine about a year ago, also, for some reason every v6 mpfi i have gotten has had a bad no.1 injector, don't know why.
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
