Timing ???
Old Jun 14, 2005 | 11:36 AM
mvftw's Avatar
Timing ???
Where should the distributor body be facing when at TDC? If I'm at the front of the car looking back, should the connectors be at 9:00?
Old Jun 14, 2005 | 12:30 PM
87blueracr's Avatar
Car: 1987 camaro & 70 mustang
Engine: 2.8l & built 351C
Transmission: borg warner T-5
top dead center of 1 cylinder or 4 cylinder, it should be pointing at the #1 plug when around tdc of #1 cylinder
Old Jun 14, 2005 | 01:21 PM
mvftw's Avatar
I know where the rotor should be, I want to know were the body should be. You can be a tooth off and still line up to #1. The body rotates a lot...
Old Jun 14, 2005 | 03:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: Timing ???
Could be at 9:00, or 10:00, or 11:00. Mine are at 12:00.
Like you said already, the body rotates, there's no way you can tell where a distributor body can be!
You need to:
1. Find TDC of #1 cylinder's compression stroke
2. Make sure your balancer mark lines up with 0 degrees after you find TDC
3. The rotor will now be lined up to 0 degrees advance.
Then pick a terminal to mark as #1. You'll need to give the distributor a bit of advance to start, so try spinning the dist body so the rotor's between two cap terminals. Mark the one "counterclockwise" of the rotor as #1, and mark the one "clockwise" of the rotor as #2.
But you can NOT, absolutely NOT, determine where your distributor body should be facing at TDC by basing it on other people's cars.
Old Jun 14, 2005 | 04:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I found my old post, read the last message in this thread for more info:
https://www.thirdgen.org/techbb2/sho...772#post357066
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
