AC Compressor brace, What years?
Old Jun 18, 2005 | 07:46 AM
KED85's Avatar
In my wrecking yard searches, I've noticed the AC Compressor braces.
My 1985, does not have that brace.
What years have that extra support?
Old Jun 18, 2005 | 10:08 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Mine does. ('87)
Old Jun 18, 2005 | 11:48 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
picture please?
Old Jun 18, 2005 | 12:16 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Is this what you are talking about?
Old Jun 18, 2005 | 12:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This is the A/C mount up for a '92.
RBob.
Old Jun 18, 2005 | 01:32 PM
Dale's Avatar
Engine: 350 S-TPI
ok, yep. I got that on my 91.
You may also need the 2 intake bolt/nut assy.
Old Jun 18, 2005 | 04:06 PM
KED85's Avatar
THANKS ONE & ALLL
ONLY other question I can ask is if your AC Compressor with brace has "more vibration" than ya believe it should?
Does mine Vibrate?
NOT SURE (don't believe so) BUT figure never hurts for hunting for that brace for upgrading shortly on a trip to the yard.
Any 1986s have that brace?
Yes I noticed the two studs (ME & WHO ELSE!?!?!)!
Old Jun 18, 2005 | 05:28 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I have that brace on my 3.1
Old Jun 19, 2005 | 05:55 PM
KED85's Avatar
FOUND OUT SOMETHING TODAY!
I CANNOT USE THAT BRACE ON MY 1985 ENGINE
WHY
The AC hoses BOLTS ON COMPRESSOR on a certain way and that prohibits me being able to "get that brace outta yard & install on my car"!
How'd I find out?
Thanks 2point8boy!
We visited while I did my smog at his place today.
It helps to have a 1989 Camaro hood open to peak at & compare notes!
Old Jun 20, 2005 | 03:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
(laughs) As I was scrolling down, I was gonna tell ya that, but you figured it out first. That brace was really just b/c of the whole serpentine setup of 87-92.
I just wish GM made separate mounts for the 85-86 a/c compressor and power steering; it's very obvious that my a/c was removed because there's a huge missing spot on that bracket. And every time I try to make one; it looks like I won't be able to make one as "solid" as that chunk of aluminum.
Old Jun 20, 2005 | 06:54 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
I have been running the car without one for awhile now with no problems. However, most of you may recall that I did install a V8 140amp aftermarket alt and had to make a custom front bracket that mounts at the 10 o'clock position instead of the 2 o'clock.
deracer
Apr 11, 2016 12:04 AM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
rh76camaro
Aug 15, 2015 12:48 PM
NBrehm
Aug 5, 2015 07:57 PM
