Throttle Body
Old Jun 19, 2005 | 01:14 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
Throttle Body
Yesterday i was driving around and when I got home, i decided to look at my engine... I noticed a hose got scorched....
Old Jun 19, 2005 | 01:15 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
and this is where its connected to the full throttle body
Old Jun 19, 2005 | 01:16 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
and finally its connects to the air canister, can someone tell me how I can fix this problem from the full throttle body to the air canister?
Old Jun 19, 2005 | 03:49 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
replace the hose
unless somthing is making your manifolds glow hot enough to melt things
rich/lean?
what else is going on
Old Jun 19, 2005 | 08:10 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
maybe it got hot off the egr pipe?
That is the hose that goes to the purge canister. I broke mine. Just re-routed it using rubber flex line. You will need to cut the melted part off so that its a clean "cut". Then use rubber flex hose to patch it. Use tye wraps to hold the new hose away from anything.
Old Jun 19, 2005 | 11:15 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Clogged cat?
Old Jun 19, 2005 | 11:59 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
did someone say scorched hose?
Old Jun 20, 2005 | 12:36 AM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
how come i dont get air out of the throttle body, from the scorched picture i just displayed?
Old Jun 20, 2005 | 02:56 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Wow! what happened there????
Old Jun 20, 2005 | 08:53 AM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
where can i get rubber flex and tye wraps, and how come no air goes into my purge canister?
Old Jun 20, 2005 | 10:06 AM
Dale's Avatar
Engine: 350 S-TPI
rubber hose can be bought at any parts store. You need to measure the od of that plastic pipe, and that will be what your ID of the rubber hose is. Or just a hair smaller for tight fit.
Tye wraps will be in the electrical section at same store.
Air does not always transfer between them two parts. It only happens when the ecm tells it too(notice elec wires on the purge tank?). Then also, the TB will SUCK air from the perge tank to put into the engine to burn
Old Jun 20, 2005 | 12:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Plus the vacuum line block at the top of the throttle body is ported vacuum, it's not a constant vacuum.
They'll call that rubber hose either "vacuum hose" or "windshield washer hose", both are the same for what you need. Some places even sell replacement plastic vacuum line, but rubber hose is all you need to patch it up.
Old Jun 20, 2005 | 12:58 PM
87blueracr's Avatar
Car: 1987 camaro & 70 mustang
Engine: 2.8l & built 351C
Transmission: borg warner T-5
get some hard vacume line too. that way you can pull the hard line out of the vacume block and put it in there right. i just did all my vacume lines this weekend for about 20$
Old Jun 20, 2005 | 10:34 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
how do i know if the air canister is purging?
Old Jun 20, 2005 | 10:41 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
And where would i do the patching, because i want to know where it would be a good location to avoid scorching of the hose...
Old Jun 20, 2005 | 10:44 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
do u happen to have a picture on how u partched ur vacuum lines... can i use them metal tie downs, the ones dat tightened when u screw it with a phillips?
Old Jun 20, 2005 | 10:48 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
With a hose like that, it's not purging at all. Replace the hose. The canister only purges at cruise, not at idle or WOT. I think that you have to have a VSS signal to the computer showing over like 10mph or something for it to purge too.
Old Jun 21, 2005 | 12:30 AM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
someone mentioned in here about lean/rich, and my car does spit out that 44/45 code... i checked the oxygen sensor... its connected and its fine, id made sure it didnt scorch
Old Jun 21, 2005 | 06:49 AM
87blueracr's Avatar
REBELGQ, DO not use any type of fastener that will crimp down on the vacume lines. as for vacume hose routing, keep it as far away from heat as possible, it is really easy to do, just put the new on while you are taking the old off, and get yourself a box of 3 way connectors!
Old Jun 21, 2005 | 10:50 AM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
Are tye downs them plastic things that wrap around? and where could i get a box of 3 way connectors?
Old Jun 21, 2005 | 11:22 AM
Engine: 5.7 / 7.4
everything at local autoparts store
Old Jun 21, 2005 | 12:19 PM
87blueracr's Avatar
you can get the vacume hose and a kit of connectors from the local auto parts store for less than 30$ i just redid all of my vacume lines for about 18$ u need the 5/16 hose. that is 5/16 OD hose.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
