oil filter bypass on my 2.8L
Old Jul 6, 2005 | 01:05 AM
mikey R's Avatar
Car: Black 89 RS
Engine: 383 ci, TBI injected, AFR heads
Transmission: TH700R4
Axle/Gears: 3.73's
should there be two oil filter bypass valves? I see one in the block and there is one on the adapter where the oil filter screws on.
Old Jul 6, 2005 | 07:22 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
bypass valve?
Old Jul 7, 2005 | 12:35 AM
mikey R's Avatar
Car: Black 89 RS
Axle/Gears: 3.73's
its a little spring loaded valve that when the oil filter gets plugged it allows oil to bypass the filter. Next time you change oil look at where the oil filter goes. There is a hole that has the bypass in it.
Old Jul 7, 2005 | 12:36 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
its designed to allow oil to flow even of the filter gets clogged
Old Jul 7, 2005 | 07:47 AM
drdave88's Avatar
Engine: 6.0L
thats right. thanks for reminding me
Old Jul 8, 2005 | 12:36 AM
mikey R's Avatar
Car: Black 89 RS
Axle/Gears: 3.73's
ok so I will ask the question again...do I need two of them? there is one in the block and one in the oil filter adapter.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
